Its the same as the Power 250.2 I know I have it, its a matter of finding which hard drive its on. I will look now and let you know.
Do you have the x-over cards in full range?
Have you confirmed the bass and treble pots are ok?
Does the channel bias?
I have placed the xover cards every which way and no change.
No bass and treble pots on this amp.
I have not checked the bias, will do that in the morning.
Sent from my DROID BIONIC
Oh yes I forgot this does not have bass and treble pots. Do any of the switches ie: balanced/unbalance or the 0/180 or the 0/180/ez bridge have any DC on the casing?
There is a 0/180 switch for each channel and one of them is 0/180/ez bridge.
Sometimes these switches being bad can cause strange issues.
I am looking for the schematic now.
I found no DC on the shroud of the switch.
Adjusting the bias pot works.
Time to eliminate the shutdown circuits to see if that is the cause.
Look at the signal on each end of the Rx89. If the amplitude of the oscillation is the same on both ends, the capacitor is open. If it appears to be open, you could connect another capacitor across it to see if it helps.
Adding a cap helped. I get noise on the lower peak of the sine wave at a certain amplitude. I will try a different cap.
- General Interest
- Car Audio
- RF 250m2 schematic
