hello..
I got a +-22V transformer (secondaries) but i need +-18. can u just unwind a bit of the wire...to get 18v..well i know i can but if i do do i need to rewind the orginal winding to cower all of the toroid core? or can i just leave about 20% naked regarding the secondairy windings??
/micke
/micke
unwinding
You can unwind, there is no problem there. If the windings are "imperfect", you will get more leakage etc, so you might want to try several angular positions when you mount the transformer (if inside case).
You could also try to use inductor loading to reduce the voltage (transformer, bridge, series inductor, capacitor bank). Search for PSUD2 and you will have a nice tool for simulating the power supply.
Its done now..by the way... i find a nice way to mount the transformer if you have a thight case...fill the "inside" the hole in the dounut of the torid with epoxy or that kind of glue you melt with a heatgun... then just screew it in without the upper mounting bracket...
works nice i think it did reduce som hum aswell..
/micke
/micke
hifi said:Its done now..by the way... i find a nice way to mount the transformer if you have a thight case...fill the "inside" the hole in the dounut of the torid with epoxy or that kind of glue you melt with a heatgun... then just screew it in without the upper mounting bracket...
/micke
The epoxy fill for the center hole is one of the standard mounting methods for toroids. The epoxy is normally put there at the factory.
The epoxy should hold the windings tightly. If the cure is slow enough, it might get through the plastic wrap on the transformer, creating an even tighter hold on the windings. This is probably the cause for the reduced hum.
The hot-melt glue is probably a bad idea. Under heavy load, the transformer could get hot enough to melt the glue (that's not very hot). This could result in some nasty damage near the transformer (as it falls
- Design & Build
- Parts
- Rewinding a Toroid transformer
