Reverse voltage protection diodes on outputs
May I ask why you would want to put these diodes on your ips or driver board.
Don't you have the space on your output section?
Or are you asking if an additional two diodes could also be added?
Good question - why do I want to relocate the diodes. Simply to clean up the back of the chassis, the driver board has room for the diodes so the only components on the heatsink besides the output transistors are the 5 watt, 0.20 ohm current sense resistors. I was curious if I could make everything a little more tidy, sounds like I can.
