Reverb replacement
I have an old Ace Tone Elite amp (~5 W Japanese amp from the 60s). The reverb tank is physically defective and I want to replace it, but I have no specs on it and I've never seen one like it (it's about 3/4" x 3/4" by 10", so very tiny). The reverb is connected at one end (not directly, but via a cap) to the plate of a 12AX7 tube. I haven't checked the plate voltage. The other end goes through the reverb pot and into the grid of a 6AV6 triode.
Based on this can anyone tell me what impedences I'd be looking for in a reverb tank?
I'm fine with one that's physically bigger. There's room in the case. I'm just wondering if I need to be concerned about input and output impedence values. I'm fine with paying $15-20 for one of the ones at Antique Electronic Supply or something. They have a bunch.
Can you see the value of the load resistor that's connected to that 12AX7 plate? It would probably help to know that.
Can you tell what sort of "actuator" that is? I've only seen or heard of (electro)magnetic in spring reverbs, but that looks different from any I've seen I wonder if that might be a piezo transducer. I can't tell offhand from the picture.
Here's some pages that may help, especially in choosing a replacement. Offhand I'd suggest going with the highest input and output impedances:
Spring Reverb Unit For Guitar
Spring Reverb
The cap off the plate type reverb drive will expect the highest impedance reverb pan input there is. In the case of the standard Accutronics and similar reverb pans, you would want the second character to be an F. That second character specifies input impedance. As in 4FB2C1B.
The common Fender type reverb drive circuit uses a small transformer and will be low impedance, as in 4AB2C1B. Most common solid state drives use the second highest impedance, as in 4EB2C1B.
In every case I know other than special order or special purpose reverb pans, the output transducer is a B type, a relatively high impedance, perfect for feeding a tube grid.
The first digit specifies the pan physical size. The 4 (or also a 9) is the full size pan, I think 17" long. The much shorter pans for smaller spaces has an 8 as the first digit.
