You could easily spend $600 on passive crossovers, and I suspect a time-aligned linear phase K-Horn will sound absolutely amazing, and it won't have the colorations K-Horns are known for (unless you want to keep those colorations, because you can EQ it any way you want).
If it were me, I'd keep them the way they are. There is no cost to doing so.
I am not the largest fan of the K-400 or the newer plastic K-401 replacement horn & K-77. I'd rather have a single, larger multi driver, multi-entry horn that can reach lower in frequency, and lower the crossover - the top end of the bass bin range is rough.
Of course, this might sound like throwing the baby out with the bathwater to some.
I did a little "looking up" on the provenance of your KHorns, and it looks like they had a Type AA crossover, which was used from 1971 until 1983. I would say that 1983 would be the youngest possible date for these speakers. Also, I have not seen the scroll work and trim on any other KHorns, and I suspect that they were added on later, although the Klipsch custom shop may have done that. If that is the case, it would make the speaker a rare beast and perhaps increase its value.
I agree with the above comments re dsp and tri-amping. I am working - too slowly - on such a design for my KHorns, which were vintage 1985.
Fun stuff.
Fun stuff.
