this is going nowhere
wrong on elemental hydrogen...it is produced as an adsorbed species on the surface of the electrode... you've read the wrong books, I'm afraid.... study some advanced electrochemistry and report back.. Bockris & Reddy come to mind
this discussion is pointless as the end result is beyond practical reach and you're convinced you're Altotus
Yeah, if you want to call an adsorbed intermediate a product, go ahead. A lack of a full valence in a pool of friendly atoms means that it exists for a short enough time to be meaningless as a "product". It's very rare for a species that only exists in an intermediate step in a reaction mechanism to be referred to as a product.
Also, this doesn't change the fact that it requires two moles of electrons, not one, to decompose one mole of water by electrolysis.
And it definitely doesn't change the fact that I wasn't talking about electrolysis initially.
EDIT: And yes, I agree that there's too many practical problems for him to feasibly accomplish this at home, by resonance or electrolysis.
In classical acoustics, a medium (such as water) does not have a resonant frequency. Instead, resonance is determined by the dimensions of the boundaries, such as the length of an organ pipe. If there are no boundaries, there is no resonance.
I don't know a whole lot about chemistry, but my GF takes a chemistry class at UC Berkeley and she was telling me that mass has no relation to chemical reaction. I guess this wouldn't apply to resonating energy but perhaps there is a way to trigger a chain-reaction through stimulation of water molecules via resonance or other means. Perhaps increasing the salinity of the water (as suggested by others) would help destabilize the target. In essence, you wouldn't need to resonate the entire mass of water but just an amount large enough to initiate a chain-reaction-fracturing of the water molecules.
AndrewT said:I'd prefer if he was a whole planet away.😉
If he does his experiment wrong, that's probably where he'll end up 😉 😀
Vaquely related to the subject: Does anyone know which (more or less) exact frequencies are required for an ultrasonic water fogger?
Wkr Johan
Wkr Johan
You mean a fog machine?
If your not concerned about chlorine gas, you can use salt as your catalyst and have sodium present in your separation device to aid hydrogen production from that point forward.
Hi.
Can't believe this thread is still alive, but seeing that it is, here is a different angle - Bacteria:
http://science.slashdot.org/science/07/11/13/2052249.shtml
Michael
We achieved the highest hydrogen yields ever obtained with this approach from different sources of organic matter, such as yields of 91 percent using vinegar (acetic acid) and 68 percent using cellulose,' said Logan. In certain configurations, nearly all of the hydrogen contained in the molecules of source material converted to usable hydrogen gas, an efficiency that could eventually open the door to bacterial hydrogen production on a larger scale.
Michael
Thread alive
talk is cheap...😀
maf_au said:Hi.
Michael
talk is cheap...😀
Water Hydrogen Oxygen resonance
So the question remains, how is the resonant frequency of water, or even hydrogen or oxygen molecules, determined anyway?
So far I have found loose references... the resonant frequency of hydrogen to be about 45khz (but I think it should be in the ghz range, eh?). I read somewhere else that the lowest resonance of the water molecule is 22.235 GHz [a microwave oven operates at about 2.45 ghz].
How is the column length for the covalent bonds measured, and then how is the resonant freq calculation assembled?
and/or
How is the column length for the proton displacement, hydrogen to oxygen, determined, and then how would the resonance freq calculation be assembled?
Which approach is relevant? I.e., what is the logic for vibrating the water molecule so that it elongates across its covalent bond?
Where else is this being discussed?
Lastly, considering that temperature is a factor, and we know that at some low temp the dialectric of water is about 80, lets simply assume for now either low temp, or not to exceed 180 degrees, os something like that.
Bottomline... I want to understand how to deduce and perform the calculation for resonance of a compound (like water) and for an atom (such as oxygen or hydrogen).
and/or
That's hilarious, I just came back here to post that! Thank you for posting that!
Now, if only I had the scientific training for really deducing my answers...
TwoHawks
TwoHawks
I meant this.
Ohhh cool, I wonder if you could increase the efficiency of those round disks by putting them in a sphere-like formation, reducing the electrical input to each device, and dropping the water into that sphere drop by drop so that it gets maximum exposure. Maybe I'm just talking out my ***, but I think it would work more efficiently.
chickenfeather said:hrm... burning water...
http://youtube.com/watch?v=aGg0ATfoBgo
Nifty, but I'd like to know how many kW he was pumping into his RF generator to get that dinky little flame.
theAnonymous1 is right. We have had hydrogen powered vehicles for well over a century. It's never a question of whether cars can run on hydrogen, but a question of whether the actual operating cost is less than gasoline.
Notice on that website there are other links to other hydrogen/water powered car. And in this case I mean cars when you literally add water as fuel.
This means nothing unless they tell us the direct cost per mile to run these cars.
Still, I hope someone can actually do it, make an energy efficient car that crack water into its constituent parts and runs of the resulting gases.
Steve/bluewizard
Steve/bluewizard
Re: Water Hydrogen Oxygen resonance
twohawks said:So the question remains, how is the resonant frequency of water, or even hydrogen or oxygen molecules, determined anyway?
Masers operate at the resonance frequency of the hydrogen atom, which is 1,420,405,752 Hz
Conventional MRI systems in widespread use generate an anatomical image of a selected portion of the human body by utilizing a radio-frequency (RF) coil to irradiate the selected body portion with radiation at a frequency of 63.9 MHz, which causes nuclear magnetic resonance of hydrogen-1 constituents (protons) in the selected body portion at 1.5 Tesla. The image is then generated based on changes in the nuclear signal sensed via the RF coil.
The two dumbest people on Earth are those that believe everything and those that believe nothing. Both are magical thoughts.
Meyer was for the most part pretty clear about his technology except for one part - the piezo devices used to limit current flow.
On the bottom of the center tubes you see a bolt extending down. The bolt is a piezo device in a form actually called a bolt. A piezo is a dielectric and this is what prevented current flow. The only current in the water was the displacement current between electrodes.
This is why he called it hydrogen "fracturing" and not the common method of electrochemical electrolysis. I have photos of all his last stuff and he used a titanium resonator in the last products instead of piezo and set up a capacitor like cell instead of the original tube design.
Two things keep people from understanding Meyer:
1. Meyer's technology changed and he patented every known method.
2. Some people don't understand that cavitation converts mass into the atomic energy contained within he mass.
Trust me, there is a whole world beyond what the kids from chemistry class know. There is an exception to the law of force that allows this and thermodynamics does not apply to cavitation and mass to atomic energy conversion.
The universe stored massive amounts of energy in mass when it was created from two longitudinal waves. Mass is really just a spinning lump of energy.
The H2 to H1 transmute took place in Meyer's injector and produced what Meyer called "greater than normal energy" output. Connect the ground to the tip of a hydroxy torch and a small plasma to the flame and you will see the effect of a much bigger flame since the positive wire extracts electrons from the H2. That was basically Meyer's electron extraction circuit.
- resonant frequency of water (distilled) and how to make speaker play underwater
