resistors
Hello,
I like to know more about sonic differences in resistors for use in small power applications in tube circuits. Like Allen Bradley, Kiwame, Mills and Yamamura. Can one say that used in the same application a Mills will sound more open and direct than an A.B.
I like to hear this kind of judgements to make tweaking of my line-amp more easily. Thanks a lot, Ed
diyAudio Senior Member
Joined 2002
RESISTORS
Ed,
Aren't you a bit overreacting?
Deciding on resistor makes will ultimately depend on what sonic results you want to achieve.
Unless anyone has tried all posible combinations the only reasonable answer I can come up with is try and see.:)
Nice weekend,
