Resistor Value
Now I have a problem with the amp staying in protection mode .
Here is what I get on the 3525
Pin 1:0.12
Pin 2:12.79
Pin 3:0.32
Pin 4:0.76
Pin 5:8.06
Pin 6:7.50
Pin 7:8.01
Pin 8:8.13
Pin 9:0.09
Pin 10:0.31
Pin 11:0.00
Pin 12:0.00
Pin 13:13.82
Pin 14:0.00
Pin 15:13.82
Pin 16:8.77
Here is what I get on the 393
Pin 1:0.00
Pin 2:2.88
Pin 3:2.33
Pin 4:0.00
Pin 5:0.00
Pin 6:4.96
Pin 7:0.00
Pin 8:13.86
And yes it’s the same amp
Five band resistors with a fourth band of gold or silver form an exception, and are used on specialized and older resistors. The first two bands represent the significant digits, the 3th the multiply factor, the 4th the tolerance and the 5th the temperature coefficient (ppm/K). Resistor color code | Resistor standards and codes | Resistor Guide
I was stumped on one of these too. So it is a 22ohm
