Resistor Value on Inverted GC
I am using the inverted GC schematic on OPA541 chip.
Normall the schematic use 10K R in and 220K R feedback which give 22X gain.
But I want to reduce the gain to be around 6-4X, the problem is should I use the higher value R in to be around 47K or lower the value of R feedback to be 50K?
What the difference do they made?
5150ed said:
You mean higher R in add more niose right?
R or the feedback resistor
5150ed said:
How about R in =5.2K and R feedback = 22K, Is this seem better?
Or R in =220 ohms and R feed back = 1K, Is this too low?
How low you can go,depends on the output impedance of the component before the amp
5150ed said:
Yep, I decide to have Tube preamp infront of my gainclone.
Do you know the preamp's output impedance?
If you have these op amp sockets, you can break off four pins and use them for resistor sockets. Just push the resistor leads until in snap into pins
