Resistor Sound Quality?
So when assembling precision instrumentation they check out the resistor orientation first..... I've never seen that done or heard of it on anything I have worked on!
Nope, it just has to be trimmed out in most cases with a trimpot. It's mostly a DC offset issue. Even if there's an AC signal being measured, the harmonic distortion from a temperature sensor or whatever isn't likely to be an issue.
Actually I tried this on my bridge.
With a metal film 1M resistor there was no difference. I had 820K in a carbon film 1/4W unit.
Measuring it one way and then taking it out and reversing it did change the 5th digit. However this all seemed to be a thermal effect from the heat of my finger tips, as it slowly would come back to the same value. So I was unable to confirm any direction issues on my samples.
All resistors have at least two junctions, maybe more, where non-ohmic effects exist - these are the lead-attach points and/or end-cap attach points at each end. Most of the contact resistance is ohmic (resistive), but there is bound to be a small amount of metal-oxide present which will cause a weak non-ohmic metal-semiconductor junction in parallel with the resistive contact.
:wiz: +1 exactly what i said ! And thermal expansion of the resistor make these semi-conductive effects fluctuating with signal modulation ....
Where are some articles on this from mainstream electronics! Any proof or just more idle speculation, because the resistor would have to be very sensitive to temp changes for this to be noticeable, and with the thermal mass of a resistor you are not going to hear this.
Then there is post #598.
This sounds like a load of bull**** and more Audiophile foolery....
And if PTH resistors are so bad use SMD!
Why is audio (allegedly) sensitive to effects which are not seen in much more demanding applications such as medical, instrumentation, military, telecommunications etc.? Everyone else builds their electronics on the assumption that resistors are essentially resistive (apart from some well understood reactive parasitics), and finds that this assumption is close enough for all practical purposes. Exceptions are carbon composition, which are known to be nonlinear and unreliable - yet are favoured by some audiophiles!
It is probably the only area of electronics I know where you get people modding boards etc. who have no idea or a very very basic understanding of electronics. Then there is the Guru factor, where someone comes up with the electronic equivalent of some new clothes for the emperor and a whole herd of devotees will follow, proclaiming it as the best improvement in sound quality, with no empirical data to back anything up.
No one buys a scope then decides to start replacing components to see if it does anything differently. A signal trace looks much the same on a cheap scope as it does on an expensive one, the expensive one (might) be more accurate though. Audio is no different, more outlay SHOULD buy performance gains by reducing compromises.
However blindly replacing components with expensive ones is just plain daft.
Much more demanding in what way? Reproducing music is not the same discipline as dogmatically linearizing a circuit. Approaching audio this way will probably shave away hairline waveforms that are meant to be there (ie:the same way an MP3 down samples). What most people fail to consider when describing the "low bandwidth simplicity" of audio is the complexity of the simultaneous waveforms with their various comparative levels having to be reproduced in the correct time envelope. It sounds like you fall into this category of dogmatic linearizers. Outside of those with a financial interest in the hospital, I don't know anyone who enjoys the sound of an EKG beep.
Yes audio is the cutting edge of electronics....🙄
You want to have a look around at what is being developed and worked on...
As to linear, isn't that one of the goals of audio....
Now now, I never said it was the cutting edge of electronics but it's a bit more challenging than just working in low bandwidth, right? I'm just really tired of the dismissive attitude directed toward audio designers by people trained in different (more advanced 🙄) disciplines.
I don't think there is a dismissive attitude to analogue designers or digital designers (audio design covers both these days), it is the fringe element that gets the flac, quite often deservedly. proper design problems, ideas improvements are supported, it is the way out ideas such as rectification in resistors that distracts from real problems with audio design.....
I agree with Andrew T, the chain of electronics should add very little to the signal from source to speaker.
