Resistor Question
Do they appear darkened especially in the mid section? probably the finishing ceramic just gotten old as time and exposure to temperature across them, but if you can clearly identify them and the test is of that identification then they should be perfect.
However, resistors are cheap you could change them, increase the watt if you’re all that concerned about them.
These are the pin size holes I was talking about .
