I'm going to build the DIY speakers from audioreview.com that call for a 5ohm, 12 watt (1%) cement type wirewound resistor. Living in Canada, my parts selection is limited to really only one company based out of Quebec.
They offer both non-inductive metal oxide and cement type wirewound ($1 metal and 40 cents cement) but only at 10 watts.
What's the difference between the metal oxide and cement type (if any) and by using a 10 watt resistor instead of a 12 watt am I going to notice anything?
I've seen some 5 ohm resistors sell for $3 - $5 USD ... much more than the ones I listed above which gives me cause for concern.
Any help would be great.
