Not a problem, just a request.
Is it possible to adjust the search so that it doesn't need to see a space at both ends of the searched term ? (Which I assume it does now.)
For example. I was looking for all references to power dissipation in the UNSET Beta Board Build thread. I know it has been discussed so to catch everything I searched "Dissipat" which on another forum under the search parameter of "Exact Match" would net "Dissipate, Dissipates, Dissipated, Dissipating, . . . . ."
On this search it gets "No results found"
Is it an option in this forum software?
Unless I miss my guess, (attempting polite understatement) there will be a few more than 27 references to power dissipation in any conjugation of the word over the whole site. Just guessing of course.
As for not reaching the Vendor area , is there a reason it should work that way?
Thanks for taking the time to check.
I would have thought so too. If this guess happens to be true, I don't suspect it is intentional.
It would be interesting to compare to a search of the old site. Of the 27 results I see they are from:
Amplifiers
Loudspeakers
Site
Design & Build
Live Sound
Source & Line
Amplifiers
Loudspeakers
Site
Design & Build
Live Sound
Source & Line
Wow, what a thought. Does the old site actually still exist?
I can tell you though, this has been a request of mine since long before the migration. I first saw a search function able to pick out any combination of text characters (including spaces!) in whatever context they appear at Audio Asylum. It makes searches much more efficient and is especially helpful when you're looking for a post you can remember having some particular use of language but not the specific conjugation . . . or perhaps a name that started with --- but nothing else. Great for searching electronics parts where only a fragment of the part number is remembered. We really should have that here.
I do remember from the old site finding posts through a search of browser history after search of the forum disallowed a certain keyword or said it didn't exist in the post I knew it was in.
- Site
- Forum Problems & Feedback
- New Issue Request : Upgrade Search
