The minimum to get this working is to add a power switch, which will connect to two wires on the white Molex connector. Add a fuse as well, 1.5 to 2A, slow-blow. This particular model includes a balance control, others had that in the tuner chassis and require a few resistors to be added. You'll want better speaker connectors than the terminal strips that Magnavox used.
