Further into the replacement of the 40409/10 transistors onto the heatsinks< is there a heatsink compound that needs to be painted between the bottom of the transistors and the heatsink surface? What is that compound? lizo
Well, thermal paste is usually used to easy heat transfer from thr transistor capsule to the heathsink, but in this specific transistor I think You don't need it.
