Need some help with ordering all the output transistors on mcintosh 2100 amp?
Where to order and how to find/order these?
The 12 transistors part Number 132-070.
Thanks: lizo
Thanks: lizo
Contact McIntosh in Binghamton, NY.. You should be able to get a service manual for your amp and possibly the output devices as well.
service manual available at McIntosh service data
Please post your findings, I need the same part for one omy MC2100 amplifiers
2N5303
I believe the 132-070 is the manufacture number 2N5303. You can double check the data sheet at alldatasheet.com We offer the 2N5303 at our company Electronic parts, Electronic Components, NTE replacement Parts, transistors, capacitors, and more!!!. I hope that helps.
Jennifer
Jennifer
Under no circumstances use ECG or NTE as replacement semiconductors for this or any other application. Check Mouser electronics as their purchasing department doesn't buy fakes like some of the other parts houses do.
