replacing op-amps in mixer
Hey,
I have just aquired a mm electronics 12 channel mixer and am going to replace the op amps on the output boards as at some point in its history one of the boards have been rebuilt and the op amps are noi longer the same on both channels (and one channel seems to be slightly noisier) they are all versions of the 741 that are being used but i want to replace them with somethign a little better and am wondering what would be best? mabey the LF351 or NE5534?
Any help would be apreciated,
Owen
having seen the inside of quite a few "high-end" mixers, I can assure you that either the lf or ne would absolutely constitude "high-end" for this application. Popular "high-end" opamps for this kind of applications are actually those TL0xx series opamps.
It is not surprising that you see the 741, or sometimes 324s in those mixers. And think all the people who argue about how much differrence they hear in those modern opamps when the signal has gone through a few 741s.
do not use tl07* series on the outputs. They do not like cable capacitance.
If 741s work, well sort of, then 5534 will give good output capability, but check for pin compatability regarding offset and compensation. You will also need to check the output gain since the 5534 must be more than times 3 or +5db from memory.
Actually, it is stable only with a voltage gain of 5 or more, not 5 dB or more. A voltage gain of 5 is approximately 14 dB. The 5534 can be compensated for lower gains, but even then it can be finicky and you should have a high speed scope to help ensure that the final circuit is stable. A lower speed, unity-gain-stable opamp would be a better idea.
the pricier options:
opa27(bb/ti), op27(ad) and lt1007 are bipolars designed in part with audio in mind
they will match/silightly better the 5532/4 on noise
opa134, opa604 are fet input and slightly noisier than good bipolars but better than 741
ad743 is the lowest noise fet op amp I know of
faster op amps may all have trouble with large cap load from long cables, 50-100 ohm series r or ferrite bead should cure any problems
