I have been trying to source the Wavecor WF182BD03 for a project, ufortunately without luck. Instead I have found the Wavecor WF182BD03 which seems to be the "same" model, just 8 ohm instead of 4 ohm.
Is it possible to calculate which modifications would be needed in a filter designed for the 4 ohm version in order to use the 8 ohm version instead?
https://www.wavecor.com/html/wf182bd03_04_07_08.html
Theoretically, yes, it is possible. You will also need to adjust tweeter level. I would not do this without proper measurement though, these wavecors deserve it.
