Hi guys, do you think it will cause any problem?? The rest of the parameters (reverse current, fusing current voltage etc..) are exactly the same. I personally feel it should be ok since its just the rated current capacity. I cant find the 25A one so getting the 35A one instead
There is a fuse at rectifier and it am keeping it the same so i feel it should be enough.
