Read back post #16. I don't have another one to compare right now... 🙂Thx but i Will start with speakers ... Cause i just bougent my behringer 😛
But ou for 1000$ what speakers or sub would you buy to get chest compression ?
Look also at the pro CVA-28 co-axs for tops. No need for a new amp. 😀
Thanks a lot , just like that , for the tops , CAN the behringer b2520 Pro be a good choice? And i you have any other. Suggestions of speakers t 1000$ that destroy more .. Make me Know it 😉
You asked for...
You can get a better/different sub for $270.00, plus extras (price includes 2x12"sub drivers) from Wayne. Include here prices for plugs/plates, wood, and all as in most diy kits.
12π basshorn driver kit
Another interesting alternative is this one for $14.95.
Tuba HT
You have to buy the drivers and all for the Tuba. There's also a big list of subs to choose from @Bill Fitzmaurice.
Tuba HT
You asked for...
Tuba HT
Does the first choice you gave me does chest compression ? Loud like CV ... I want a lot of air moving on my room ... The thing to get the closer as possible of the JH 90 if Danley Sound Labs 😛.
Also, it might help you choosing the module if i told you that i listen music like dubstep and lot of bass. I dont want to have just the vibration but also when the béat Côme it hits. You Know what i mean ?
Un the pi horn sub at 270$ whats inside ? And why so Much cheap un price , is there something missing ? Are the subs going to Broke easily? CAN i pût my amp to the Max without having to care of the speaker Will blow? .. Explain me .. 😉Does the first choice you gave me does chest compression ? Loud like CV ... I want a lot of air moving on my room ... The thing to get the closer as possible of the JH 90 if Danley Sound Labs 😛.
Hi manoli337,
I explain,
You must research yourself, not me saying this, but it's one of the best subs "world class".
It does give you "chest compression" for sure... a big one! But better to ask Wayne Parham, he built them and he can answer that question better than I am. I would say; very close to Danley's... (don't look at the price and buy all the extras, meaning faceplates and heat exchangers). See, with "Heat Exchangeeeeerrrrsssssss..........." it doesn't break easily!!! 😀
http://www.pispeakers.com/catalog/product_info.php/products_id/263
http://www.pispeakers.com/catalog/product_info.php/products_id/262 (complete with sub enclosure, CNC flat pack?)
I explain,
But if you are in the living room (small room, not PA) with room gain and all consider the more significantly small, maybe a pair of them? I don't know the size of room and amps (can't remember).
three Pi subwoofer kit
Pi Speaker Kits, Subwoofer Kits, three Pi subwoofer kit
three Pi subwoofer (complete with sub enclosure, CNC flat pack?)
400 watt subwoofer with 12" driver capable of extension to below 20Hz
Pi Speakers, Subwoofers, three Pi subwoofer
No, it's just 2 Eminence Lab drivers for one sub and the plans for the 12Pi basshorn subwoofer. 😀My amp is a behringer Inuke 3000Dsp
The 12pi subwoofer at 270$ its just the box ?
The flat pack kit link as seanny said above it's here - 12Pi basshorn flat pack kit (only/note: doesn't say it has the drivers)
The 3 links with different possibilities/prices for the kits/flat packs and finished enclosure.
http://www.pispeakers.com/catalog/product_info.php/products_id/266
If the flat pack doesn't contain the drivers you should add up kit #1 (drivers) and flat pack #2 with the CNC cut wood, ply or MDF (I'm not sure).
picture link
picture link
For Sub-Woofers ...
... check out these
Rythmik Audio • Direct Servo subwoofer products
WHG
hello, i have 2 subwoofer that are blown in my home. i want to replace them . but i dont want to put a cheap car sub as a replacement. do you have ideas and brands of 12" subs not too expensive ?
https://fbcdn-sphotos-h-a.akamaihd...._=1377983416_107625c7885a8db93a3d7533a25fcb08
2 modules like the one at the left...
thanks
... check out these
WHG
Is it gréât a cerwin Véga ab horn subwoofer
And with my behringer Inuke 3000dsp witch pa loudspeaker i CAN buy to it boom ?
Thanks , something bigger and a bit cheaper..:/
- replacement
