I have an unorthodox question.
I bought outdoor omnidirectional speakers that are supposed to be buried say 4 inches into the ground to have optimal performance (according to manufacturer and everyone else that owns them):
TIC GS5
Amazon.com: TIC GS5 5" Compact Outdoor Weather-Resistant Omnidirectional In-Ground Speakers (pair): Home Audio & Theater
The catch is I can't bury them (we can go into the details later). So I was planning on putting them in large planter/flower pots. However, I don't know if adding soil into the pot to pack in the speaker will yield the same result as as burying them since soil in pots tends to be dry/looser/less compact as burying them in the ground. I was trying to determine what the best material would be to fill in the flower pots.
I originally was thinking just concrete, but that might not bond to the plastic of the speaker and therefore eventually decouple because of expansion/contraction/vibrations and then just vibrate up against rigid concrete which could add/subtract weird sounds when used. Then I started thinking about maybe using a mix of clay and soil which I could control the density to replicate soil. I would think the best material would ideally compact to form a nice tight surrounding around the speaker but still be able to dampen the plastic vibration and mimic the resonance of the speaker when traditionally buried.
Does anyone have any ideas/thoughts/comments/etc?
Thanks!
TIC GS5
Thanks!
Crushed glass sandblasting media? I’ve used in the past for filling hollow metal tubed equipment & speaker stands, as well as large void chambers in speaker enclosures.
Thanks!. Why did you end up choosing that material vs something else? Pros/cons/etc
Taylor, I chose the crushed glass as is was a readily available and much cheaper alternative to lead / copper gun shot that was in vogue before ROHS became a religion. I’ve also used clay based kitty litter for filling enclosed speaker void, it doesn’t have the mass density of glass, and I’d be a bit concerned about moisture with it. Decorative landscape rock or pea gravel would certainly work as well.
But there’s probably many ways to skin this cat. PETA relax, that’s just a figure of speech
- Design & Build
- Construction Tips
- Replacement material for dirt when using in-ground outdoor omnidirectional speakers
