Hello Guys
can you please suggest me some better op amp instead of ka4558s and this is a SIP case, because i found this op amp in my tuner which is marantz St 6000 and now i would like to replace it. Also is it possible that i implement AD826 into the tuner since 826 is made in DIP case?
here is some info about ka4558s http://www.fairchildsemi.com/ds/KA/KA4558.pdf
Thank You
Alex
Thank You
Alex
You could make a little PCB adapter. SIL limits your choice.
I would use a TL072 -- no stability issues and it's very good sounding. I wouldn't go for anything more exotic to be honest.
aleksandar said:Hello Guys
Thank You
Alex
look at opa2134, unbeatable for the money, easy to apply
best
Guido
