Replacement Crossover Caps Needed
Adding on what Mark said, a value of 8.2uf is the equivalent of an 8.0uf capacitor with a 2.5% tolerance; a 2.5% tolerance spec is still very good and very likely greater than the tolerance of the specs of the capacitors you are replacing.
