The Manual States "If replacing these capacitors, the value shall be higher than 0.1uf"
So to make sure the language translation is correct,
They (Elekit) do not want a value Less than .1 uf correct?
It seems to me that increasing the caps to .2 uf or even .3 uf
would move the low end down and increase the base response.
I'm saying this because I have done the same in other
audio circuits and have good results
Any issue with doing this?
