Replace VR tube with zener string?
I infer it takes 1 minute for the regulated voltage to rise to 60% of spec level when the zener current is 5mA, and at t=0 the regulated voltage starts at 0V.
That is opposite of the VR, where VR voltage rises up to strike voltage at the start, so could sit at a high level for a while until it strikes.
For some applications, that difference in start-up may be an issue - it would depend on an assessment. So it may not be as simple as using it instead of an ss zener (which is effectively instantaneous).
Like Elvee wrote, Figure 4 is a normalized graph of the drift of the voltage versus time rather than of the voltage itself: Delta Vz(t)/Delta Vz(infinity) rather than Vz(t)/Vz(infinity).
When you look at the schematic diagram on page 248, there is no component there that could cause a 1 minute time constant - microseconds maybe, but not much more. The only thing that can be quite slow is self-heating, which also explains why the graph of Figure 4 changes somewhat with a small heatsink.
I agree with you that the voltage across glow discharge reference tubes is too high until they start. In fact it is as high as whatever supply voltage you apply to them; feed them from a 225 V rail via a series resistor and you get 225 V until they start.
The ambiguous definition for me relates to the dV/dt of the infinity value. Maybe there are more detailed specs or reports on the drift of the reference level itself, but as I see it, that particular chart is not clear in what information it is trying to convey. Maybe it is related to the test circuit #1 (SS 0038) in that datasheet.
Elvee how did you derive the 3.2mV? (which I see as 0.01% of 33V, not 0.0001%)
To add to what Marcel said, the curve shows the effect of the thermal time constant on the thermal drift: for example, if the voltage value when hot is 10mV higher than at 25°C, the graph shows how these 10mV are reached over time
I completely messed that one: 3.2mV is the tempco of 3.2mV/°C, not an absolute value, and I mixed up the decimal places
