I am a beginer diy from Thailand. I plan to build Balance ZEN preamp and Aleph 5. But in Thailand I can't find IRF610 and IRF9610.
What happens if I use IRF510 and IRF9510 replace with
IRF610 and IRF9610 in Balance ZEN preamp.
Is sound quality change ?
And if I replace that mosfet, have any value in schematic need to modify ?
Thank you
Thank you
I also like the 510 but where I am, only the IRF510 are available and not the complimentary IRF9510.
Is it possible to use the IRF510 for the amp stage and others (eg IRF9620 and IRF620) for the power supply?.
Also since the IRF510 has Vds=100V, will the power supply need to be change say from +-60 rail to +-50V rail?
