Repairing MTX 1501d - Help a newb
So I finally got the cajones up to try to fix this smoked mtx 1501d I got scammed on.
Replaced all the 75339 fets (all shorted out) and a couple melted poly caps right near them.
There's also a cracked (looks like physical damage) diode I replaced that leads to the fet in the center of the board.
I think the previous abuser of this amp "modded" it, since Q240 is missing.
So on first power up (no speakers, no inputs) I get the power led and about 3 seconds later LED238 near the input section lights up.
LED399 in the center of the large caps never lights.
Trying my test again with a speaker connected and an audio source. Soon as LED238 lights I get a very faint buzzing on the speaker. (About .1 volts on the dmm).
No idea where to go now. 🙄
doh!
I should of thought of that. (I had to replace one on that 6100d I was messing with)
There two of them, and they're both open.
I'll have to see if I can clean them up. They're a little dirty from the magic smoke, as if they weren't hard enough to read to begin with. 🙂
Does "39R2" sound about right? I got one clean as I could and can still barely ready it with a magnifying glass. 🙂
Is there a size to these little smd resistors? Last time I ordered SMD diode's, they were too small to even cover both solder pads.
