Repairing Denon AVR-1602
Hi Chris,
I've tested the amp with an old speaker and all channels work. The manual derguteton posted didn't say what the voltage should be across the emitter resistors, but I'll call the distributor tomorrow. Even though they don't do repairs, they might know.
The answer - read the manual
Hi Brannigan,
After reading the manual, your final value is 8mV. There is a procedure for this on page 12 of the downloaded manual. Did you download the PDF file?
I found I needed to use IE to get the manual, the site didn't like Netscape.
-Chris
Edit: wrong page corrected
Hi Chris,
On page 12 of the manual I downloaded there's a part of the schematic for the front board. The text on page 12 says:
ALL RESISTANCE VALUES IN OHM. k=1,000 OHM M=1,000,000 OHM
ALL CAPACITANCE VALUES IN MICRO FARAD. P=MICRO-MICRO FARAD
EACH VOLTAGE AND CURRENT ARE MEASUERD AT MO SIGNAL INPUT CONDITION.
CIRCUIT AND PARTS ARE SUBJECT TO CHANGE WITHOUT PRIOR
NOTICE.
The manual I downloaded is 19 pages. I assume yours is the same?
