Repair help wanted for Realistic HP-100 Electrostatic Headphones
Need help finding a part to replace a 3.3 ohm PTH variable resistor. Is this a MOV, PTC, Thermistor? I do not know what a current replacement part would be.
Thanks for the help!
Steve
See pic:
It is a PTC (positive temperature coefficent) thermistor, from the schematic here
AudioKarma.org Home Audio Stereo Discussion Forums - View Single Post - Realistic HP-100 Eletrostat
which is post #13 in this thread
Realistic HP-100 Eletrostat - AudioKarma.org Home Audio Stereo Discussion Forums
The third part down on this list from Mouser might be a good choice, without knowing the specifics of what is coming out of your speaker terminals. The rating is (3.3R) 60V and 4A, which should cover a lot of amps
Mouser Electronics - Electronic Component Distributor thermistor
95 cents and in stock...
http://www.mouser.com/ProductDetail/Murata/PTGL09AS3R3K4B51B0/?qs=sGAEpiMZZMsFah5lC2HR3Vz%2fPXOufO9UcmBLKDCK%252bk0%3d
Suggestion: if it were me, I would buy two and replace the one on the other channel too. Since this one went the other probably won't be far behind (age), plus they will match.
Good luck!
