Hi Alan,
You would feel better after learning some. The outputs are the output transistors. Drivers are the ones that "drive" the outputs. You are catching on.
The caps are working, otherwise the resistor wouldn't get hot. Go ahead and put this aside until you get some test equipment. Learn on the web and the library.
-Chris
-Chris
