Hello,
I would like to know what is the relationship between Excursion Xmax, Surface area Sd, of the driver and the Frequency it can Produce?
(I am trying to compare passive radiator in terms of this quality)
Thanks in advance.
There is none between only those parameters. There is a relation if you include the sound pressure level and assume a closed box (and drive the unit to it's xmax).
Ok can you tell me that relationship?. I asked this coz i had seen a chart of frequency, Xmax and Sd for a case with same acoustic power. (I think it was for closed box case)
