REL Quake driver specs
I already have two of the drivers, new old stock. Having the specs for them would help me to work out the best way to use them.
REL technical support were friendly but said they didn't have anything for that model. Obviously someone at REL will have the specs but I wouldn't expect them to go out of their way to find the information for me.
OK now I see. Yes I second the suggestion to measure your own specs, even if you had them from REL. It's not too hard if you have a computer with soundcard, power amp and voltmeter capable of reading millivolts. If you are interested I can send you a draft version of a guide I have written which I would appreciate feedback on.
Ok, as promised the first set of results, before running in.
OK, here we go after 12 hrs of 20Hz. Vas up a bit, Fs down. Much as I would expect really. I may well knock up a box to test Vas with the volume method, just confirm, but I don't have huge doubts about the above figure.
OK, I found a rough 32L box I could use, it's a bit leaky, but it will do for a quick check. Knocking off 2l for the driver, we get the results below. I suspect this is as good as it gets. Definitely not a sub driver I feel.
Hmm, now what to do with them? Put 'em back on eBay? 🙂
