...with feedback.I got 5W at less than 2% distortion with nice bass.
Please measure FR curve at 5W, and distortion at for example at 30-40Hz.
Yes, i agree.jan.didden,
You said: "Bob Pease also said a lot of sensible things, so don't judge him by that."
I agree. And I was not being critical of Bob in my earlier statement.
And Bob's remarks about simulations was actually one of his strong messages, and very sensible.
One person who just graduated in engineering school, asked what he should do to help him on his way to be an analog engineer.
Bob said something along the lines: 'have you been tinkering with circuits for years'.
Another reader asked how they took a brand new analog IC design and "optimized" it, after the first ones were produced.
Bob said something to the effect that they did not optimize it, they designed it from experience to work properly (predictive engineering).
Simulation can be helpfull, but only if proved in praxis.
It's like autonom driving, in theory everything works.....
But please, no more porridge. ThanX.
For me Nelson Pass is the right way, if he told the first Watt is the important one. And with feedback you can reduce something but not everything. Better there is no need for feedback....with feedback.
I'm confused.For me Nelson Pass is the right way, if he told the first Watt is the important one. And with feedback you can reduce something but not everything. Better there is no need for feedback.
Earlier you rejected the Skunkie mods out of hand, at least in part because they employ feedback.
Later, you say you're using her feedback scheme.
Now you say no feedback would be better. OK. No need for feedback would mean running either triode output tubes or triode strapped pentodes. Yet, earlier, you said you weren't interested in sims of the amp in triode mode. So you seem to have rejected that idea, too.
Running in triode will result in less power, of course. But since you have very sensitive speakers and also support the notion that the "first watt" is the most important, having less power shouldn't be a concern.
So I'm puzzled by your lack of interest in triode mode which, arguably, would produce the best quality "first watt" without using feedback.
Isn't that exactly what you're trying to accomplish??
Oh no doubt at low frequency they aren't doing this well and we all know that. I was measuring this distortion curve at 1Khz, but the amp as delivered passed 1% distortion at 0.05W using the same 1Khz test. So much for a "good first watt" lol. I ended up with 2W at less distortion than the stock amp had at 0.05W, which I would hope most people would see as an improvement....with feedback.
My mods are a huge improvement over an otherwise horrible sounding amplifier. And no, it's never going to equal an amplifier that uses output transformers that one of them costs more than this whole amp does. 🙂 It did turn out to be a very decent sounding amplifier after these mods for a less than $500 tube amp.
No no, you somehow misunderstood me, i will not have and i'm not using any feedback.I'm confused.
I will only change the operating points of in- and output tubes . No less, no more.
A lot of people use tube rolling for changing something. This is, changing operating points.
HiYa Stephe,Oh no doubt at low frequency they aren't doing this well and we all know that. I was measuring this distortion curve at 1Khz, but the amp as delivered passed 1% distortion at 0.05W using the same 1Khz test. So much for a "good first watt" lol. I ended up with 2W at less distortion than the stock amp had at 0.05W, which I would hope most people would see as an improvement.
there are different ways to improve this one. I did some tube rolling, and yes, now it got some better. But this is an expensive way to go. There have to be reasons, and this i'm looking for.
My first impression with my La Scala was not bad, but after some time i was missing only a little bit of something...
OK, I guess I must have misunderstood your earlier post. Perhaps there is a language issue.No no, you somehow misunderstood me, i will not have and i'm not using any feedback.
I understand that you want to experiment with operating points on the input tubes. But I was asking about the output tubes, not the inputs.
Any response to the rest of my post?
Pentodes, when operated without any feedback, are not linear. You may be able to drive them better using different operating points for the input tubes, but that will not make them linear.No need for feedback would mean running either triode output tubes or triode strapped pentodes. Yet, earlier, you said you weren't interested in sims of the amp in triode mode. So you seem to have rejected that idea, too.
Why don't you simply run the output tubes in triode?
- Tubes / Valves
- Reisong A10 / A12 SE EL34 AMP
