Joined 2002
Steenoe >.
Are you saying i should ditch the 4 x 10k caps ? i was thinking about keeping them and not using briangt's psu board's if all goes well.
If you want to use the regulatorboard as a complete PSU, you will want to keep them. Some of the things in my first reply is based on the board used only as a regulator. You can ofcourse also have the rectifiers onboard then.Are you saying i should ditch the 4 x 10k caps ? i was thinking about keeping them and not using briangt's psu board's if all goes well.
Steen.🙂
Joined 2002
Back to this priject im going to put on the following suggestion's.
In Put power terminals
Output terminals
Led For power
Dual secondary's.
Thicker traces.
Maybe more cap's 6.
Rail Fuses.
Any other suggestions ?
Then i plan to build a few.. id like to build a pair for a mini a amp.
Output terminals
Led For power
Dual secondary's.
Thicker traces.
Maybe more cap's 6.
Rail Fuses.
