Regulated PSU??
"An amplifier receives a wave of electrons at it's input and produces a facsimile of that wave at it's output by modulating it's power supply according to it's transfer characteristic" (© Gordy, 2007)
So, yes, use a regulated supply.
Ideally use a supply with a low and constant output impedance over the audio band.
Read-up on pcb routing.
Use by-passing capacitors close to the chip power pins.
Remember that ground is also signal return (in conventional terms).
Remember that ground is also electron distribution (in unconventional terms).
