Regulated power supplies in a Gainclone
I did some power testing for my dual LM3886 amp. I have non-regulated power supply. 8 parallel 33 ohm / 5W resistors were used as a load (= 4.125 ohms). I only tested one channel. I could only get 1 V p-p signal from my USB card. This was enough to get 18.9 V RMS or 55.2 p-p signal into load. This equals 86.6 Watts into one channel! The resistors soon got very hot, and i had to turn down power. The peak current was 6.6 A, still smaller than the 11.5 A current limit. There was no clipping. The ripple was 1.6 V. The supply voltage dropped from 33.0 V when idle to 31.4 V at full blast. I have 4*4700 uF capacitors on the PCB for power supply filtering and 2*24 V / 250 VA toroid transformer. The LM3886:s did not get very hot while testing.
See http://hepso/misc/Lm3886_amplifier.html for more details about the amp.
I´m always a bit puzzled when people write "the chips only get slightly warm" and the like cause the LM38XX chips are probably the "worst to cool"-amplifiers cause everything happens in a very limited space/volume.
At 35V rails which don´t sag down at full load you can indeed achieve a good 80W into 4Ohms but only at a power dissipation of 60W.:bigeyes:
I mean we won´t use that power level permamently
(in case we would that´d be the last amplifier I´d build)
but I can´t believe you didn´t burn your fingers or at least the temperature protection kicked in after a few minutes.
Show me your heatsink or go and check your skin with the doc.😉
Jens
jkeny said:
Has anyone got report on how regulated supply sounds in comparison to no reg supply and if it worth buying parts & building
Pedja doesn't give much info - simply says it does all he expected it to do?
John
Hi John,
Yes, and it was about having a midrange as it is with unregulated 25V supply. But, using the same existing 1000uF as local decoupling caps, regulated supply has more airiness and bass is notably better (goes low as with 25V and is tight as with 30-32V unregulated supply). And then you can use here Black Gates (say 100uF or 220uF) without robbing the bank. With such supply for GC it might happen one will forget all the theories of musty energy in capacitors that kills the music. That enough?
Pedja
Jens
I'm using 10 mm thick aluminum, 100 * 100 mm, and aluminum case. My test was not very long, only about minute or two was enough to make the load resistors hot.
If the heat sink is thick enough, the chips don't get much warmer than the the heat sink. There must be enough metal to move the heat away from the chips. They say that silver is bad conductor, copper is worse and aluminum is really bad...
Has anybody tried to build a GC with silver heat sink? That would be high-end 🙂
That makes perfect sense then.
Most of the gainclones seen here don´t have that thick bare metal to move the heat from the chip very fast.
I used a little cooling tube with a little fan which is very effective once it´s hot but it wasn´t able to move it away from the chip fast enough.
Added a thick peace of aluminium and it did the trick.
Can´t seem to find the sheets for heat conductance of different metals but from my memory : Is it really worth it?
What about gold then.:devilr:
Cheers
Jens
thermal conductivity
gold is worse
silver is the best heat conductor metal, copper is second, alu third, as ukram already told.
in these materials (metals) thermal conduction is dominated by electron movement, so electrical conductivity behaves same as thermal.
Diamond for example is also a good heat conductor, but is electrically isolating. Thermal conduction here is by phonons (lattice movement).
Now, a silver heatsink, and diamond isolation material, that is high end!
Copper is already MUCH better than Alu, and Silver is not so much better than copper.
You could easily build a GC with a copper heatsink for a PC.
