Do you have a Multimeter (DMM) to measure and prove your suspicions about the resistors? There's not a lot to be gained by guesswork and appearances even with the best schematics and advice in the business.
The resistor values are shown by colour coded bands and there are plenty of charts with explanations to read the values on the web. Here's one to get started with: Electronic color code - Wikipedia, the free encyclopedia
The resistors in your pic. are 5-band coded and don't read quite the same as more common 4 band types.
Try this neillll. It lets you put your colours in and gives the value,
Resistor color code calculator - 3, 4 and 5 band resistors
The bad news as others have hinted... there's probably more amiss than just some low wattage resistors.
- Rega Brio resistor question
