My first preamp was a DH100, and I regret ever selling it. I'd always wanted a DH110, but by the time I'd acquired this one I had so much other gear to use that I never bothered to give it any work to do. It went into storage.
When I did hook it up recently, I got some really disturbing results out of it. Overall the sound wasn't good, and I know these pre-Rockford Hafler units can be very nice sounding. The volume pot in particular was very bad. At around the 1/3 mark it had a sharp transition between barely audible and listenable, and it made cracks loud enough there that I thought I'd better power the thing down, and give it away.
Or fix it.
I pulled open the cover, and started looking over the insides:
- No debris, no dust even, so the PO obviously did some preliminary work
- Two of the eight BJTs on the board that wore heat sinks were missing them
- no electrolytic caps have burst or leaked, but a few of them exhibited a little bit of "pillowing" on top, where the "Mercedes logo" relief cut had a little hill in each of the three sections
- other than a tiny bit of what's probably cleaning residue near some clusters of BJTs (and nowhere near any caps), this board is pristine
My questions so far:
- I'm pretty sure the pots need to be cleaned. Especially that volume pot. I'm new to this and have never done that work. I have CRC/QD contact cleaner, MaxPro contact cleaner, and Deoxit F5 on hand. I'm sure that whichever one of these I try to use, it will be the wrong one, I'll put it in the wrong spot, it'll destroy the pot, and when I come back here to report it, everyone will say "why did you use that? You should have used (x product)!" so I figure I'd ask here first - what should I use, and how?
- Hafler used a frame-type transformer mounted diagonally in the back corner, so I can't convert to an IEC plug without major surgery (no room). Has anyone here done an IEC retrofit on the DH110, or at least upgraded to a better 3 wire cord?
- I'd like to source the caps myself. If I replace just a few caps, I should replace all 24 of them. The Hafler assembly manual parts list is riddled with typos and is not brain-friendly (the BJT list is especially badly done - whomever did it freely mixed up the letter I with the number 1). Would anyone here have a more concise list available?
- If I turn out to be not smart enough to figure out the cap values, is there anything wrong with going to "that guy" on eBay and buying the complete cap package for $43?
- What brand of capacitors are recommended? I am open-minded to both the arguments against esoteric caps as well as the arguments in favor of them. I think both have good points, but there's a law of diminishing returns. Silver sounds better than tin, but I can't tell the difference between gold and silver -and apparently some people can- is what I'm saying. So what "audiophile-grade" capacitors are a good value, if there is such a thing? I'm also open to buying a lot for a volume discount, if that helps.
- Where do I find the goofy little stamped copper heat sinks for these BJTs? They're about 2/3 the size of postage stamps and made to fit TO-92 packages. They're probably pretty important.
Or fix it.
