"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
Thanks xaled,
Not sure what you are getting at, the boards don't have a use-by-date so not sure what fresh boards will offer.
I've measured the current draw of the Red Barons, they are the same. The master/slave links are about 30mm, I don't think that would be too long. Since I get good music with either Red Baron connected separately it must be either a problem syncing them when parallel or with the Tube-I-Zator somehow. Though reducing the I/V to 20 ohms must certainly mean it isn't over driven. I have changed the tubes with no change in distortion. I've reflowed solder joints though none looked bad.
New Red Baron pre-order list
Hi Oliver,
Red Baron V5.0 is an excellent board, so you will have no problems to collect 20+ order.
As for me, I have need for at least four Red Barons V5.0 for today only.
Plus four PCB for future needs, so I can order eight PCB right now.
So you already have pre-order list for 10 PCB:
insatiable - 2 x Red Baron V5.0
noizas - 8 x Red Baron V5.0
I tried the USB Amanero and it worked with both Red Barons connected. So I hooked up the Twisted Pear again and it's working too. I don't know what it was. I must have connected and reconnected everything about 20 times and all of a sudden of it goes.
Thanks, Rick
I've found the issue. It is the relay board. When I connected the USB I went straight to the Red Barons. I wired everything back up through the relay board and the distortion is back with the spdif . Oliver, do you have any relay boards left? I'm sure it's a relay but I build a new one from scratch if you have.
Rick
Rick
ppap64 - 2 x Red Baron V5.0
xaled - 4 x Red Baron V5.0
Guys, if you want to build the RB with the onboard I/V converter, you will need the DC Reference Module, too.
Please add it if needed!
Rick
Rick
The relay pcb is sold out, sorry. Use the OTTO-II form Twisted Pear Audio. 😉
Hi Oliver
Ok..I need to slow down and get things right. I for sure want the onboard IV so I will add the DC reference module...I am hoping to do a dual mono RB setup using Ian's i2S to PCM board in simultaneous mode. Would I need 1 or 2 of the DC Reference Modules ?
Are the PSU boards in stock also ?
ppap64 - 2 x Red Baron V5.0, 2 x DC Reference Module
Hi Oliver
You will need one DC Reference Module for each RB. The +/- PSU Module, TDA1541A Shunt Module and +5V Shunt Module are in stock.
:wave:
aive - 2 x Red Baron V5.0, 2 x PS, +/- 15V Shunt Modules (Hey Oliver, I presume 2 boards are needed for balanced output - one board does +L, +R and the other does -L, -R?)
End of pre order
aradan- 4 x Red Baron V5.0
Guys,
as we are now over the needed 20 pcs., the pre order ends on 30th September.
All who signed the pre order list, please PM me your paypal address for the invoice.
Best regards,
Oliver
updated order
ppap64 - 2 x Red Baron V5.0, 2 x DC Reference Module, 2 x Salas shunt reg modules(+5,-5,-15)
