"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
I recommend 0.6mm solid core silver wire for the power connections from the shunts. I also agree that connecting to the old TL431 holes is impractical and suggest scraping a nice centimetre line of trace and soldering a silver wire to it, for strength and electrical solidity.
Otherwise, I'm guessing Oliver has considered this mod, and if he decides to do this for himself, he will perhaps consider designing a new smaller board, or am I wrong Oliver? 🙂
The TL431 holes are 0.7mm diameter, so you could use a normal AWG24 / 0,511mm or AWG22 / 0.644mm solid core wire. 😉
Salas shunt regs and huge banks of Panasonic FDs for each channel is proper hi-fi, problem-addressed-engineering luxury, with low impedance, high ripple rejection, low ESR, clean DC. These shunt regs are absolute world class.
To then stick a little factory bastard on the end like the TL431 is perverse to me, unnecessary and not a real hi-fi solution. This was Thorsten L's advice if I remember right. In fact, it's not a solution to anything at all - there is no problem to solve!
Hi Mr. Oliver:
I need some of your PCBs:
-Separate Shunt regulator module for additional parts (5v)
-Tubizator PCB V2
-Shunt regulator module for Tubizator
They are all available?
Thank you.
Yes. PM send.
I can't view the photos uploaded at my country. They are showing a frozen frog. Are there any other way to view it?
Witch photos you can´t see?
all 🙁
btw,
+/- Power Supply Module: $23
TDA1541A shunt regulator Module: $20
Shunt regulator Module for add. +5V line: $10
TDA1541A DAC Module: $18
Professional 2-Layer PCB: $32
The last thing i need to get is the output from PCM2707/6 IIS right?
can you PM me ur paypal address and above charges inclusive shipping to malaysia?
btw,
Hmm, you could see all modules also in the Members Galery here on diyaudio.
If you want to build my complete DAC, you need:
2x +/- Power Supply Module: $46 (four voltages lines)
1x TDA1541A shunt regulator Module: $20
1x Shunt regulator Module for add. +5V line: $10
1x TDA1541A DAC Module: $18
1x Tube-I-zator V2.0 Module: $30
Because you want to use the PCM2707/6 (VDD=3.3V) as II2S converter you need also a buffer IC in between,
e.g. my Ultra High Speed Buffer Module ($10).
Worldwide shipping: $ 9
paypal fee: 3,9%
If you want to order, please send me a PM or a mail to diyaudiopcb (at) gmx.com with your paypal address.
:cheers:
Hi Guys,
I am debugging my setup, as I have zero sound.
Setup:
-Doede Douma's SPDIF to I2S converter
-Single TDA board
-Home built output stage (discrete)
Likely suspect is the output stage, but I would like to rule out the rest first. Maybe you can help me:
-What voltages do you measure at the I2S input of the TDA board?
-What voltages/amps do you measure directly at the output of the TDA chip?
-How can I otherwise verify that everything up to the output stage works fine?
Thanks!
