"Reference" TDA1541A DAC with I2S-BUS architecture
Surface Finish for future PCB´s
  • ENIG - Electroless Nickle/Immersion Gold
    Votes: 93 48.7%
  • Immersion Silver
    Votes: 54 28.3%
  • Immersion Tin
    Votes: 24 12.6%
  • OSP - Organic Solderability Preservatives
    Votes: 20 10.5%
  • Total voters
    191
I have made a small "Ultra High Speed Buffer" Module, for the three data lines we need.
To get no interferences between the data lines, i made a discrete layout witch based on the fastest single buffer chip, the NC7SZ125.
Perhaps i will produce a few of these modules...🙄
By the way, what are you planning with the tubizator 2.0? Integration of the shunt?
No. The shunt stays a separate module.
Just wait a few days till i am ready. I will post the changings.
:cheers:
P.S.: I have start the production of a small batch from the "Ultra High Speed Buffer".
The width is the same as the TP WM8804 pcb, so you could mount it on top.
Ultra High Speed Buffer Module
The Ultra High Speed Buffer Module will be shipped "ready to use",
with three NC7SZ125 chips soldered.
The specifications are:
- 2mm pcb
- Immersion Gold
- green soldermask on both side
- 35µm copper weight
- Board size 50mm x 42mm
The price for it is $11
Worldwide shipping: $ 4
paypal fee: 3,9%
Thanks Oliver... I think we all appreciate the effort your are putting into this!
By the way, I need more shunts 😀, but more plusses than minuses. In total 3 positives (+19v, +15v, +12v), and one negative (-19v). You did not perhaps have some single positives lying around, do you? 😉
Alternatively I can get some from Quanghao, but would be nice to fit them all on the same stack...
I have the TDA1541A shunt module and the +5V signle shunt module here. 😉
Doedes SPDIF board works with Olivers TDA1541 board, but his USB board does not.
Doede's USB board works fine with Oliver's TDA1541 board if one omits R28 and R31 from the latter. Well, that's how I got them going . . .
Sorry to be dumb but what does a high-speed buffer do that a normal speed one doesn't?
