i have a 1996-97 polished aluminum soundstream reference picasso class A amplifier which was working fine. it didn't wow me so i decided to replace all capacitor except for the ceramic ones, 24 -diodes 5402, 24 -1ohm resistors 1watt, and all transistors, tip102, tip107, ndp7050 (replaced with ndp7060), and the biasing pots. As for fep16dt, fen16dt, mc7815ct, and mc7915ct i removed them from the board but decided to not replace them because i couldn't find replacements.
the caps was replaced with same value, the ultra low esr caps i replaced with the panasonic ultra esr caps, and the rest of the caps with replaced with audio grade caps elna silmicII and nichicon. the 8 polypropylene caps were replaced with solen audio caps 4.7uf 400v.
i touched up all the vertical boards on the amp 6 total with solder.
after all my hard work and spending over $300 in parts i was finished.
i now am going to adjust bias to 20mvdc but am not able to moving the pot to its minimum the bias is at 14mvdc and at its maximum it is at 19.6mvdc. each pot doesn't get affected by adjusting the other. so if i leave one pot at 17.6mv and adjust the other pot the first pot doesn't get affected it stays at 17.6mv. across the 1ohm resistor it is average of 8.8mv. the pots i purchased are 500ohms and is marked with 501 but the original part is marked with 500. i tested both pots and at its minimum they are both about 500ohms. thinking the pots might be the cause i replaced one of the pots back to the original pots and problem still remains the same. from my notes the bias adjustment should be able to adjust from 0 to over 100mvdc but should be set to 20mvdc +/- 5mv. what might be the cause of this.
i decided on setting all pots to 17.6mv and now its time to test all outputs.
all channels work and play music but for some odd reason on the front left channel of the amp the level is double the loudness compared to the other 3 channels. what can be the cause of this? would it be the 1 channel being faulty or the 3 channels being faulty. all 4 channels play without distortion and before i replaced all the parts on the amp all channels played the same no sound level differences.
please help. this is idiotic and stupid of me replacing parts on the amp which i know nothing about.
Hummmm... have you checked the gain pots and the switches like Perry suggested?????
The switches are the most likely suspect, but I have seen the gain pots become un-aligned with one another after some un-knowing hands had been inside the amp before myself and they for whatever reason pulled out the shaft that connects them together and accidentally left one gain pot out of alignment with the others......
Other then that I would check for DC voltages on the op-amps inputs and outputs, and make sure the lower 15 volt rails are properly balanced and equal🙂
how to perform this test "Other then that I would check for DC voltages on the op-amps inputs and outputs, and make sure the lower 15 volt rails are properly balanced and equal" sorry you are speaking to an idiot with no electronic circuit background.
the switches looks new like someone changed them i can tell by the soldering job and flux residue on them.
do you think the problem is with the 3 channel or with the 1 channel. i assume it is with the 1 but not sure.
how about the bias pots why am i only able to adjust from 14 to 19mvdc and this goes for all 4 channels. would the ndp7060 cause this?
Have you read Perry's web-site yet? It will tell you how to read voltages on op-amps to see if any of them have failed
This is how they looked originally so don't go by flux contamination as to weather someone before you has replaced them. The switches on all of these SS amps are a very big problem, so don't over look the possibility that they might have dirty or bad contacts
I am fairly sure you have a single channel issue.
No the mosfets in the power supply have really nothing to do with the bias controls. What are you rail voltages ??? take the black probe of your voltmeter and connect it to the center tap of the transformer and then with your red probe measure each supply rail both positive and negative should be equal. The only reason I can think of for the bias not being as high as spec is because it is either limited by the factory or some supply voltages are not correct
Really please study Perry's tutorial it will inform you about what you are doing and how to go about what you are doing. It could have saved you much money so far and a lot of un-needed replacement work. Plus now that you have pretty much gutted the amp your problem is still present and in your mind you are now in doubt of the work you preformed and the new parts you installed. It is very important to follow a procedure, and the most important thing was to figure out what was wrong in the first place then replace parts as needed. Once the problem has been dealt with all of the new things you wanted should have been a piece of cake. But with all of the upgrades and such they confuse the original issues you have now. Sort of a catch 22 you are in now...
Read Perry's tutorial... Take it at you own pace... It will show you how to do all of what you posting about. 🙂
the rail voltage is 23v and -23v, the one channel that is louder than the rest sounds as there are more high frequency sound coming out of them compared to the rest i'm testing the amp on a bench with a 4ohm 5 1/4" focal midrange speaker.
what must i do to properly balance the lower 15v rail.
yes i do have perry's tutorial i purchased it about 6 months ago. there is tons of reading that i haven't really read yet. i should probably start.
thanks for helping i really appreciate it.
"what must i do to properly balance the lower 15v rail."
What are the lower rail voltages? There are not going to be the exact same but should be very close < within a few milli-volts of each other >
For the channel to have off frequency response and less volume I am thinking either the FEB is defective or the signal from the front end is bad to begin with, but without a definitive testing of the switches those would be my second best guess's at this point.
by chance what are the DC offsets of all the channels at the speaker terminals especially the off channel ? This is often a good indication is something is off spec in the circuitry.
lower rail voltage are +/- 15
dc offset is
FL: 5.0mv
FR: 1.5mv (playing louder than the rest)
RL: 1.5mv
RR: 3.0mv
all op amps has +/- 14.57v (off 12v power supply)
after really listening to it the one channel playing louder than the rest sounds the best in my opinion and 4 of my friends who i asked to listen to it the loudness sounds as it is double the loudness of the rest of the channels.
dc offset is
FL: 5.0mv
RL: 1.5mv
RR: 3.0mv
Is there a switch for high/low RCA input?
If so, set it to the position where the amp produces the highest audio output for a given input level. Does that allow all 4 channels to play at the same level?
can you get a hold of jaime and ask if he has 4 feb boards and the two pre-amp (i think thats what they are) boards in stock i would like to purchase them. for the 1996-97 reference picasso class A polished aluminum amp.
is it posible the resistors near the rca to go bad i check a couple of them and the some of the value are incorrect would i need to lift up one leg before testing?
how did you know i was an idiot Mr. Babin. the amp operates at same level now i had one of the switches on the balance side so i correct all switch to correct location and amp works fine now. thanks i was so close to ordering all parts on the amp to renew the entire amp.
another question is i heard about people doing op amp swaps with the amp i would like to install the bur brown op amp can someone reference me to the correct ones to work with this picasso class A.
I'd suggest leaving the op-amps. Any change in sound quality is likely to be imaginary and unless someone has tried the op-amps that you use as replacements, it may create more problems.
The balanced/normal switch rarely makes a difference in level. Can you move it and cause the level to go up and down?
If not, the problem was a dirty contact in the high/low level switch. In the position that produces the lower level output, the switch shunts part of the signal to ground so less reaches the amplifier. When the contacts are dirty or intermittent, the signal isn't shunted to ground and remains higher than the others.
one last remaining issue with the class A picasso is i am only able to adjust the biasing pot between the range of 14mvdc - 19mvdc. i remember there being a wider range before 0-80mvdc. are the 500ohms pots i replaced the old ones with not the correct ones or is this normal and i should go ahead and max out the pots to get 19mvdc. this is across two different diodes. across the resistor at max i get 9.5mvdc.
You won't hear a difference between 1mv and 20mv.
The turn-on threshold may be different on the replacement transistors so the bias control may not have enough range.
Hi Perry, while I respect your opinion I have to disagree on the imaginary thing regarding op-amps.
This week we replaced the OP275 on two of the four channels with OPA2134.
This enables us to do back-to-back testing between channels 1+2 and 3+4 by simply moving the RCA's and speaker wires to the other channels. The source, wiring, speakers and music remain the same. The difference in sound is very apparent.
For instance on the Picasso the OP275 has more high frequency response and more low frequency responce than the OPA2134PA, which has strong mid frequency response. This alone affects the sound, and this is only one of several differences.
Thanks to the sockets we are using we can swap op-amps real fast on for instance the 2 channel Genesis amp for almost-immediate comparison of the music and yes the difference between op-amps is very noticable.
We had to spray some contact cleaner in the notorious Soundstream switches. The 2.0 / 5.0 volt input gain switches probably are the worst so we replaced them on that specific board since there was a lot of dust and corrosion in them.
I find it strange his board won't go beyond 19 mVDC bias. How much power supply voltage is the amplifier getting ? The bias will be different at 11, 12, 14 volts etc.
If, for instance, you are using a car battery as power supply on your test bench the voltage will drop well below 12 volts after powering on an amp, and so will the bias.
Recommended bias is 25 mVDC for this particular amplifier. The bias will be higher after a couple of minutes after being powered on. When you raise the left channel the right channel will also rise considerably, and vice-versa. On the Rubicon Class A's, it's opposite. When you raise the bias of the left channel, the bias of the right channel will decrease a little and vice-versa. Also, the bias on the Rubicons does not rise like it does on the Reference Picasso after being powered-on for a couple of minutes.
What is VERY important on Reference amplifiers is to retouch the driver PCB solderings. Especially on Picasso's they are very bad and can cause multiple problems. And the switches, like always. We very gently hit the housing of on of the stereo/bridged/mixed-mono switches on the Ref Picasso with the back of a screwdriver and the sound on one channel was cutting in and out. Contact spray cleaner and working the switches back and forth many times does the trick. Bad solderings on the driver boards were also causing problems on this board, but they are easily solved by applying some soldering to all of them, including the smaller control boards. By moving the driver PCB's gently around while the amplifier is playing music the sound on one channel might cut in and out and you might cause a temporary short circuit and see excessiver current draw on your test bench's power-supply. On this particular board one of the chokes had overheated so we replaced it and the nearby rectifiers just to be sure. It never hurts to replace the rectifiers on these Soundstreams.
The solderings on the Rubicons are better, generally.
Probably the top 3 problems on Reference and Reference s / sx amps are driver board solderings, switches and rectifiers, not necessarily in that order.
Rubicons have their own problems, though probably less of them.
azvrt:
Try this. Have someone change them or leave them. You don't know. Sometimes they will change them, sometimes they will leave them as they are (you never know what's installed). Listen 10 times without having a clue as to which op-amp it is. Can you pick out the one that sounds so wonderful 100% of the time?
If they never change the op-amp, can you say that you would never say that the op-amp has been changed when it has not?
Would someone else that has never heard the amp be able to do the same?
If you can't do this without error 10 times or 100 times, the difference must not be pronounced and the belief that they sound much better must be imagined.
The only difference you can expect is a small decrease in the noise floor.
This assumes that the replacement op-amp is behaving properly and not creating something that you can key on (sometimes they have a faint oscillation).
This is a problem with experimenters. They expect to hear a difference so they do. They make a minor change and hear an incredible difference (soundstage just opened up, wonderful highs, tighter bass...). I'd bet that after they make 10 'upgrades' (all making an incredible difference, in their opinion) that they could not pick their super duper project from one with all original parts (this assumes that the original was properly designed by a competent design engineer). This is why I cannot participate in some of the forums. Too much snake oil being sold to unsuspecting newbies.
One example that stands out was an amp that was intentionally underbiased. It created a bit of crossover distortion. When listening to the underbiased amp, the amp had an 'airy' sound, more harmonics. This was especially pronounced with female vocals or a cello. In virtually all instances, the listeners thought the underbiased amp sounded better when it was actually more distorted.
Just because it's different doesn't mean it's more accurate or better (unless you like the distortion it adds). The op-amps aren't likely to add any distortion (but could if they're not stable in the circuit) but you can't rule it out unless you have the test equipment to verify it.
Thanks for the suggestion, it makes sense to perform this test, yes. Will do.
I won't be checking for distortion (in most occasions) so if we do pass the test one might contribute it to distortion.
However, I must say that if a certain sound is pleasing to my ears and that sound turns out to be caused by a certain type of mild distortion, that's perfectly fine with me. It would be a shame to choose a technically more correct sound over a techically less correct but more pleasing (to the listener) sound. In other words the technically perfect flawless sound might not be the sound a certain person likes.
If the bass seems stronger with a stronger op-amp, maybe it can be proved with an oscilloscope ? For instance, play test tones at the same volumes at 70 Hz, 700 Hz and 7 kHz. If the op-amps are playing equally loud at 700 Hz but not at 70 Hz then it would be clear ?
In the end I won't be enjoying the music in my car with measuring equipment but with my ears.
In my opinion, what's important is that you don't fall into the same mindset as other modders. If you want to deal with facts, you need to test in a way that gives definitive results.
It's unlikely that the low frequencies will be affected by the op-amps unless the previous op-amp was defective. Op-amps all work about the same with low frequencies.
If there is a difference at 70Hz, there is likely something wrong with the circuit.
thanks for the input from everyone helping me resolve my issues. if i raise the bias to over 20mv i will hear difference in sound quality? if yes how will i go about doing so if i'm not able to turn it past 19mv? is it tip102/107 i need to replace, i am currently using on semi. Or is it ndp7050 (replaced with ndp7060)? fep16dt/fen16dt(replaced with fep16dta)? mc7815ct/mc7915ct (replaced with mc7815ctg/mc7915ctg)?
if the switches are switched to the 2v side all 4 channels play at same volume but if i move it over to the 5v i get that same problem of one of the channels playing louder than the rest. my headunit is sending a 5v out wouldn't i need it to be in the 5v position?
the bias doesn't raise to much after being powered on i believe i have the reference version its a blue board.
You won't hear the difference with higher bias.
To make it go to greater bias with the current parts, you'd likely have to modify the circuit (change a couple of resistors).
In my opinion, you don't need to replace anything if it's producing clean audio.
The switch would only need to be in the 5v position if the amp reaches full power at a very low setting on the volume control. If you need to use it in the 5v position, you will either have to replace the switch or jump it out. For testing, you could solder jumpers between the pins that have the bad connection to confirm that it's the switch.
You should try and find out whether you can hear a difference with the bias set to 19 mvdc and for instance 15 mvdc. If you can´t hear the difference, set it at 19 mvdc and don´t worry about it. Still, I find it strange you can´t set it any higher on that particular board.
I had the exact same problem you have with the 2v / 5v gain switches on a Ref 644s and 500sx. Replacing the switches (buy them from Jaime) should do the trick. You could also try contact spray cleaner which might also help.
At some point I replaced an old switch with a brand new one and it did not work properly ! Sprayed the new switch and never had problems since.
Blue boards are Reference. Very strange the bias doesn´t raise much while the amplifier warms up. Very strange you can´t set the bias any higher. I wish I could say something more useful but I don´t know the answers to that.
- General Interest
- Car Audio
- reference picasso class A issues
