Hi all,
does anybody konw the command to switch the polarity on the dam 1021?
Thx and greets
Christian
Thx and greets
Christian
Soren, as I understand the board is optimized for -/+4V on Vref for 74LVC595A shift registers which is already bit more than the -/+3.6V specified as max recommended in datasheet. However datasheet states 6.5V for Vcc as absolute maximum rating.
I want to try "hot rod" mosfet shunt regulator (Zout 1mohm) for direct Vref powering, however cannot go as low as 4V due to mosfet Vgs. It works above 4.6V.
So, do you see any dangerous or disadvantages running Vref at ~ +/-5V? Should this work theoretically without problems?
Thanks,
Thanks,
those shift registers are pretty tough ive tested to 6.5v
5v should be ok at least for a test
Hi all,
Thx and greets
Christian
set=invert (for reversed polarity)
set=normal (for reversed reverse polarity) could not resist ...
dear Rick
thx for answer. i think this answer was pretty close but doesn't work.
i tried a bit an it seems to be:
set mode = normal
set mode = invert
if i just enter set i get a feedback for all set commands 😉
but i am not sure, if it realy works. if i enter for eg set volume = -50 or set volume = 0 there is no change in volume but if i enter just set i get the feedback, that volume is changed ;(
is it maybe not changing during playback?
greetz
christian
set mode = normal
set mode = invert
greetz
christian
dear Rick
set mode = normal
set mode = invert
greetz
christian
I was writing from work and relying on my memory (yikes!)
I typed it that way initially and then I thought the "extra" spaces were wrong so I removed the spaces.
I am using a free hotkey program so I do not have to type all of that and since I do not have to type it regularly it was not remembered. One of the downsides of convenience!
Good thing: umanager's "?" key shows all the possibilities, though I was a little hesitant at first to experiment. Fear of screwing it up. Don't worry, it ignores what it doesn't recognize.
I hear a difference when I change the polarity. I am absolutely sure it works on my DAC and should on yours, also.
Unless I have completely fooled myself, which is something I worry about all of the time!
I, too, have noticed nothing changing with the volume control. I thought it might be a good idea to set the volume a little lower since so many new recordings are at such a high average level. Wondered if there was the possibility of overloading the DAC. I am using 3.3 volts on the shift registers and thought: maybe this is a good idea. So I did.
Then a few days later I was playing a recording with very low levels so I thought I would return it to zero and there was no difference at all.
I use an autoformer after the DAC output to set volume levels not the internal. Maybe there needs to be a pot attached for this to work? I do not know. I have left it at zero ever since.
But to reassure on the polarity - it does work and is a good addition to a great device.
set volume = -50
Sets the inicial volume when the power ON.
To lower the volume:
outside umanager
V -50
outside umanager
V -50
Hi I have Soekris dam dac v2 with lot of mods, work great! but I still wondering what to do more. I have heard that i can disolder analog opa's. Im working on raw out put. This mode give me better sound? I have looked on board and I have see that from 2R2 ladder is connected to raw out and to a analog opa's , mayby just cut connection from ladder to opa?
Hi Soren, is it trivial to add bal-left-invert and bal-right-invert modes? We would like it very much. Would help us dual-mono follks out. 🙂
Ta
Ta
Ta
Next dam1021 firmware will add the normal/inverted phase runtime command, that's what you really need....
Awesome, thank you!
Der Søren,
does it mean, that at the moment the "set mode" command is not setting the polarity during playback?
If not: when should it change? after reboot?
Thx and greets
Christian
Thx and greets
Christian
The "set mode =" uManager command is for setting power up parameters, not designed to be used during audio playback, and it's undefined what happens during playback, it require a power cycling.
The single letter run time commands is to be used during playback.
ah...ok 😉
but what is the single command for changing polarity? don't know where to find these commands because i think they are not in the manual.
I and N ?
thx and greets
christian
I and N ?
thx and greets
christian
ah...ok 😉
I and N ?
thx and greets
christian
There is no polarity runtime polarity command in the dam1021 yet, it is in the dam1121 and will be added to the dam1021 in next firmware update.
So you are saying it is impossible that the polarity change can occur during playback?
I have long maintained that a placebo audio tweak is as good as any as long as the illusion lasts!
I sure thought I heard a difference. Hope I can maintain the illusion ...
Well, that's a little more than a little embarrassing.
I guess this applies to the filters, also?
I know there is only so much that can be done but not being able to switch during playback makes it close to useless since this is something that can change between tracks, let alone, albums. Oh, well ...
I said "undefined", some of the "set mode=" commands might work during playback, but I have done no effort for it to, I don't test it, and it might change in the future....
Dear zfe,
You are able to measure things.
Could you see if the polarity switch works during playback?
I would hope I would be among many grateful to you if you could.
Edit: Just thinking - could one feed the SOEKRIS say a 100 hz sine wave "file" and simply use an AC voltmeter to see if the polarity changes?
Thanks and take care,
Perhaps after all you do change the polarity as even Soren cannot confirm what exactly happens during runtime when you activate the command. I guess if you change the polarity now same way you did before, but now after your confidence is shaken, I guess you will hear the difference if it is real, meaning polarity can be changed during playback.
Did you also investigate if polarity can be changed in SDTrans? I am going to check now if I can change the polarity in my cd transport signal processor. It would be cool and elegant if one could change the polarity this way by just applying H or L to a corresponding IC pin.
Dear zfe,
I was only able to trigger the invert/normal change (after set mode =...) with a power cycle.
Exiting back from the "+++" level does not change invert/normal.
Things that work with loading new filters during playback (switching inputs and/or sample rate) did not change the invert/normal state.
By the way, BOTH channels get inverted. Invert will be of no use for correcting recording where one channel was accidentally inverted.
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
