Is this going to ship with some sort of manual?
I am still curious as to how three or four boards can be synced to use it with a three or four way active system????
Søren posted recently that a manual will be ready when the boards ship - he was finishing the firmware for release and would start writing the documentation once that was done.
There was some discussion in this thread about multi-board setups. You'd have to dig back and find the posts.
** Just checked the first post and see that Soekris has just updated it with information that first batch is sold out, and second batch is close to being sold out.
I wonder how many DIY oriented products sell 600 boards in less than 3 hours?
Does nobody read the first post ? There are ordering info with links up now....
I suspect most members have their preferences set so that they see the most recent posts when they click on a thread.
Physical:
3.2" x 5.8" (81 x 147 mm), two PCB mounted XLR connectors on one side for the balanced output driver.
Power:
Takes 2 x 7-15V DC or AC. Designed for single 2 x 7-8V 5W toroid transformer.
Paid for one 0.2%. Thanks Soekris.
Please for the traffo: how much VA advised if a 2x9V ?
2x9V trafo is not recommended as it don't leave margin for line voltage and load variations....
But not much power is needed, playing music at full power here I have a load of 2.2W at +-10V DC.
Thanks Soren,
Any Mouser/Farnell/Digikey ref advised for this traffo ?
Will come with the "manual" ?
There is a Farnell part that was suggested by a member:
MCFM50/07 - MULTICOMP - TRANSFORMER, TOROIDAL, 2 X 7V, 5VA | element14 Australia
Element14/Farnell are out of stock.
However, there is a UK based eBay seller who does have stock:
MCFM50/07 Multicomp Mini-Toroidal , 5Va 2X 7V | eBay
I got one from this seller and the transformer arrived in Farnell packaging.
Payment is sent for 1% x2 pcb
I would like to use 2 pcb for dual mono ,how to jump input Chanel.(i2s (USB) ,SPDIF )
So Soren recommends at least / around 10V in post #766 and 2 post later You link to 7V trafos...
Hi Soekris, I can't order the board more than 5 pieces, so I have to place 2nd order (expensive shipping cost!). Could you combine two orders into one for me?
Hi I Entered in the website from Soekris.eu, I make two orders but it said that not products yet made.
I am interested but I need to know the "D" day.
Best Regards
Best Regards
Soren has always recommended 7-8V Transformers... that's around 10V DC which is what his post was referring to.
Soren,
Just wanted to know if balanced unbuffered output using two dacs is already implemented for first batchs or would be postponed to a later firmware ?
Thanks for your kind answer.
Søren has repeatedly said 6-7V and 5W, and said a couple of posts prior to mine that 9VAC is too high.
10V refers to DC voltage - and obviously if you rectify 7VAC to DC you get:
7 x 1.414 = 9.898V DC or close enough to 10VDC
The reason Søren is warning against using 9VAC is that the rectified DC voltage is:
9 x 1.414 = 12.726VDC which is fine while the Trafo is loaded.
But the off load voltage output by the transformer can rise by around 18-23%. The one I linked to has a regulation spec of 18%.
So unloaded:
7VAC x 18% = 8.26 x 1.414 = 11.68VDC
9VAC x 18% = 10.62 x 1.414 = 15.016VDC
Even at 18% off-load regulation the 9VAC secondaries are at the maximum limit of the board.
The 10VAC Trafo you think Søren was proposing:
10VAC x 18% = 11.8VAC x 1.414 = 16.68VDC = toasted Soekris R2R DAC.
cheers
Paul
I will use 15-0-15-0 troidal transformer and this regulator.
4.17uV Ultralow noise DAC power supply regulator +-12/15V 1A - DIYINHK
at the end u get 12v 1A regulated power.
There might be a qty 5 limit for first batch to control things, but send the website where you ordered a note and I'm sure they will combine....
Hi soekris,
I have just ordered and paid for a board on the EU website.
I am a little confused - will it ship on Monday ?
So unloaded:
cheers
Paul
You also need to account for line variation, I typical put that at +- 15%.
So at max 16V DC internal gives: 16 + 0.5 (diode bridge) / 1.15 (high line) / 1.25 (load reg) / sqrt2 = 8.1V
And at min 7V DC internal gives 7 + 0.5 (diode bridge) * 1.15 (low line) / sqrt2 +1 (ripple) = 6.8V
So trafo have to be specified at 2x 7V-8V AC when you account for line and load regulation. But nothing stops you by powering it by a DC power supply....
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
