Hi
I am still searching gold-plated reed relays around the globe. With no sucess!
Any hints (supplier, link) of a member. It looks that Burmester is the only one who found one!
Tolu
Tolu
If you want gold plated contacts and normal relays in 2 form C (DPDT):
Panasonic TQ, AGQ, TX, D2E-S series
NEC/Tokin UA2, UB2, EC, MR62 series
These are available in 4.5, 5, 12 and 24V coil varieties, depending on the manufacturer and series.
Hi Alan,
thanks for your reply but I have plenty offers for gold-plated electromechanical relays.
Reed relays are the problem because they are hermetically sealed. All I have seen so far had contacts of Rhutenium or Rhodium.
Gold contacts are used because gold resists corrosion better than almost any other metal. In a hermetically sealed relay (reed relays) this is not very important. It's too bad mercury contacts can no longer be found, tests indicated mercury had no sonic impact on a contact.
While gold has excellent corrosion resistance, its' sonic qualities are subject to debate, most fancy cables and wires no longer come with gold contacts.
I suspect that the Rhutenium or Rhodium would be more than just fine, they may actually be superior for sound quality. I have a great deal of faith in George Cardas, he uses Rhodium on all his better products.
My faith in George stems from the simple fact that any product of his I've used, did and performed exactly as he said it would. Additionally he has extensive documentation on his site about what has worked for him and usually why.
Commercial passive pre-amps that use relays face the same issues you face. To the best of my knowledge, all the better ones seem to work fine without the benefit of gold contacts.
As an easy solution to mounting the VC on the back of the amp to avoid an extra cable. Why not make a 1.5' integral cable sticking out of the VC. No extra connectors or solder points than putting it on the back and 3-4' of really nice signal cable should be relatively cheap to come by.
