I would...but shipping to Singapore and the exchange rate will kill me...so I guess I will stick to my 160W speakers...
Hi
I'am very nervos about my modified xformer ...
I have to admit my winding is not perfect , it's unregulated in some places , etc etc ...
Is there the magetic field of the xformer will affect my amp modules ? It's normaly if the winding are not perfect that the magnetic field and the elctric field to be modified .. incresed ..
How do you think ?
Thanks. Mihai.
How do you think ?
Thanks. Mihai.
Just make sure it's well insulated..you get the right voltage...and ensure you have good grounding and seperation...if it doesn't work out well..get a new trafo~!!!
Saluate omule
Daca ai disponibili 1.000.000 Lei i-ti dau un toroidal de 650W 2*32V 10A / Rail original original.
Cauta-ma pe mail la audio@home.ro poate mai vb. si despre altele
OK
Am rezolvat problema cu toroidalul printr-un stabilizator de tensiune IRF. Daca o sa am nevoie te caut .
It is not nice to speak romanian when all the people here speak english.
so you say you solved your problem with a IRF regulator ?
what`s that ?
i think it would have been easier to rewiind the transformer .
PS: those kits suck big time i had a few and the best you can get is 150w/8ohm
what`s that ?
- Reducing Voltage in a safe way.
