Good Morning,
I opened a 1987 issue of The Audio Amateur and read a letter to the editor by L. Rusch of Glenham NY. Mr. Glenham discussed a 10 watt amplifier he had built following a circuit in a RCA tube manual. The 6.3 volt tube heaters were supplied with 5.4 volts and demonstrated lower noise as a result.
I have heard of this effect before but not experienced or explored it myself.
Does anyone in the community have experience or knowledge of the effect of adjusting heater voltage vs. tube noise?
DT
All just for Fun!
DT
All just for Fun!
With low-power valves, reducing the heater temperature (by lowering voltage) will usually reduce noise.
The mechanism: at full working cathode temperature, with a tube in new condition, the emitted electrons will show a distribution of energy levels. Some will be energetic enough to leave the cathode and reach the grid [if grid-cathode voltage is low] - and if this makes up a continuous flow it will be measurable as grid current.
Reducing the cathode temperature will lower the energy (hence velocity) of the electron emission, and so reduce grid current.
Grid Current is the focus when dealing with Noise in valves. We should distinguish between two types of noise - Noise from the thermal agitation of electrons (thermal noise/Johnson noise) and noise from the discreteness of the electrical charge (shot noise).
The grid current described is small and haphazard because electrons are emitted by the cathode randomly and independently - their arrival at the grid is like rain on a tin roof. This is Shot Noise, rather than Johnson [thermal] noise, and is the dominant noise effect in a triode.
Operating the valve is such a way that grid current is lowered will minimise noise.
- lower cathode temperature
- low anode voltage
- lowered anode current
These lowered parameters will generally reduce gm, which may increase thermal noise. But with a tube, Shot Noise effects overwhelm thermal noise by a big margin.
With transistors, increased collector current gives lowered noise, and many a sand-head gets into trouble with tube design on this count.
Also, one must choose a sample set of tubes with low gas, since ionisation grid current is also plagued by shot noise.
Old tubes may also get noisier due to accumulation of cathode particles on the grid, leading to grid-emission current - also a shot-noise prone mechanism. Warming the cathode before applying B+ is a possible precaution to minimise this particular risk.
- low anode voltage
Hello Rod Coleman and All,
Interesting insists into noise in circuits.
I suppose that when the ‘’valve” was designed heater voltage, noise, gm, mu and the complete list of variables was taken into consideration and the important variables were optimized. Now 70 plus years later we (I am) are rediscovering what they learned then. Perhaps the valve used where low noise was more important grid current was minimized. I am also thinking that not every circuit required this consideration.
Now we are digging through what remains of NOS valves and using them for other than their original application. Perhaps this is the other end of the scale of trying to maximize the audio power output of a television sweep tube.
It may be worthwhile to breadboard a tube like a 5670 vary the heater voltage and observe the noise floor on one of the new fangled FFT PC setups. I say 5670 because I have some NOS JAN GE’s. They were manufactured to tight standards. The noise variable was specified and controlled. It may be possible to lower the noise floor of a valve RIAA preamplifier.
DT
All just for Fun!
DT
All just for Fun!
Grid noise should not be an issue at audio frequencies. It becomes noticeable from about 20Mhz and up. If you have sufficient grid current for the noise to be an issue then you probably have enough grid current to cause distortion too.
The main noise source in a triode is called shot noise, and comes from the discrete nature of electrons as they hit the anode. However, the space charge around the cathode smooths things out considerably so shot noise is much less than it could be. It ends up with the shot noise being affected by cathode temperature as described by Rod Coleman. This makes me suspect that so-called 'shot' noise is really another form of Johnson/thermal noise, but complicated by the fact that there is not thermal equilibrium in the valve. Shot noise is equivalent to the thermal noise current produced by a resistance equal to 1/gm, at an absolute temperature of about half the cathode temperature. Lowering the cathode temperature will reduce noise at first, provided that there is still enough emission to provide smoothing. Reduce it too much and the noise gets worse, as the smoothing goes.
Pentodes have an extra noise source - partition noise. This is similar to shot noise.
Hello All,
More Interesting insights into noise in circuits.
So far we have Shot noise, Thermal noise and Partition noise with Shot noise identified as the most prominent.
Shot noise is identified as being related to the absolute temperature and resulting velocity of the electrons (charged particles) leaving the cathode. I am not sure is the noise is the result of grid current or electrons hitting the anode perhaps both. Not to discount other possible explanations.
If I was one the research group at MIT in 1941 studying noise in electron tubes I would have been more suspecting of high velocity electrons hitting the grid rather than the anode. In Class A there is a cloud of electrons striking the anode, a couple more or less would get lost in the cloud. A small number of electrons with velocity high enough to overcome the repulsion of the negatively charged grid seems to me a likely culprit. I do not know, just thinking noise.
More Thoughts?
Anyone ever adjust the heater voltage to reduce Valve Noise?
DT
All just for Fun!
More Thoughts?
DT
All just for Fun!
An electron captured by the grid instead of the anode would cause exactly the same noise current (antiphase) at both electrodes. This would be an example of partition noise. It is not true that among so many at the anode you would not notice a few missing. The difference would be down to different circuit impedances (so the same noise current causes different noise voltages) and gain from the grid. Grid partition noise is not likely to be much of a problem in a healthy triode when properly biased. The grid leak bias recommended by Wavebourn guarantees a very low grid current, so no noise from this.
The official line is that triodes do not have thermal noise, but shot noise related to cathode temperature as this affects the statistics. As I said, I find this suspicious. True shot noise is not temperature-related, but comes just from the discrete charge of the electron. This is how a noise diode works (used for measuring the noise factor of a radio receiver).
There is another noise source - the cathode. It is believed that cathode impurities are responsible for flicker noise (1/f noise). Unlike shot noise and partition noise, flicker noise depends on the detail of valve manufacture (e.g. cleanliness) and material quality so some manufacturers will be better than others, and valves designed for audio are likely to be better than those intended for RF or switching.
Tube (Valve) noise is a complex topic, I have found.
Shot noise Partition noise, Thermal noise all add up from many interacting causes. We as users have limited control. We can do a few things. Previously I did not given it much thought, noise happens.
Today I spent some time reading about Valve noise in VACUUM TUBE AMPLIFIERS Valley and Wallman Editors and ELECTRONIC DESIGNERS HANDBOOK Landee, Davis & Albrecht . The bulk of the information was about RF receivers, not limited to audio frequencies.
As stated by Rod Coleman and DF96 the primary noise is shot noise. From what I read it is not so much individual electrons striking the surface of electrodes as rain on a tin roof but random variations of the intensity of the electron cloud in terms of energy and number of electrons. The random uneven flow of electrons being the cause of the shot noise. Individual high velocity electrons striking a surface can dislodge multiple electrons; this is secondary emission, another kettle of fish.
Besides selecting tubes for their noise there are two things I took away from the books we can control regarding “Valve” noise; absolute cathode temperature and plate voltage. Cathode temperature affects the number of electrons and the velocity of the electrons in the cloud. Reducing anode voltage has a limiting affect on electron or current flow through the Valve. With reduced flow of electrons there is lower average random variation of the electron cloud and reduced Shot noise as a result.
Just a couple of things to think about, perhaps play with.
DT
All just for fun!
DT
All just for fun!
Hello All,
I have been reading through the old school stuff. Even bought a hard back copy of MIT Vacuum Tube Amplifiers edited by Valley and Wallman from Abe Books. I also have ordered a copy of High Fidelity Amplifier Design by Chrowherst and Cooper.
Noise in valve amplifiers is not a simple topic. The old school for low noise was detection of weak radio signals. The MIT book, a result of the WWII effort has 220 plus pages of valve noise discussion and low noise circuits.
Some tubes were designed for low noise some like the 6922 have lower noise because of “modern” mass production techniques. High gm is typical.
There is a lot to sort through.
Does anyone have any noise as it relates to audio references to toss out?
DT
All just for fun!
DT
All just for fun!
I am finding the occasional noisy valve in my projects.
After spending lots of time hunting down hum and getting rid of it I found a couple of valves with a crackling type noise. Its not constant and I don't think it is RF as I use 10k grid stoppers. Its definitely crackling and not voices.
If I replace a noisy valve with another from same source it doesn't do it or it does it much less.
^ what he says. Grid current noise should be negligible for the narrow bandwidth of audio in the scheme of things. The irreducible equivalent input noise should be about the same as that from a 300R resistor, by careful selection of valve type, from all sources - which is pretty quiet in the scheme of things, except perhaps for MC phono stages.
One type of noise that can dominate and isn't mentioned very often is flicker noise - a random variation that follows a 1/f law and sounds like crackle/roar, and varies from valve to valve. AFAIK its mechanism is poorly understood, at least by me! This originates within the valve, and is the only type of noise likely to vary with heater voltage/cathode temperature.
Low heater voltage can have a downside for valve life, as uneven heating of the cathode means emission current might be borne from spots on the cathode surface which can degenerate progressively and shorten life.
So, unless flicker noise is a problem which won't go away with valve substitution, personally I wouldn't consider playing about with heater voltage to reduce noise.
HTH!
LD
I disagree. To quote myself:One type of noise that can dominate and isn't mentioned very often is flicker noise. This originates within the valve, and is the only type of noise likely to vary with heater voltage/cathode temperature.
"At anode currents less than about 1 mA, reduced heater voltage gives a distinct improvement in EIN, but at higher currents the situation reverses. At the low-current end this is thought to be due to the starvation effect, where a slight reduction in heater voltage actually causes gain to increase, while the reduced cathode temperature also reduces shot noise. At higher currents, however, reducing the heater voltage causes the gain to fall, and at a faster rate than any reduction in anode noise current."
Hi Merlin, yes I really enjoyed that read from your most excellent AES paper, based on measurements. That's mostly where I formed my opinions. At risk of being cheeky and quoting you back, one conclusion was :
In most cases the total noise in the audio band was dominated by the flicker effect.
I thought that since you observed heater voltage to affect noise, it must do so by the flicker effect, which is dominant. This, in combination with a 1960 paper Schwantes & Van Der Ziel which discussed 'noisy spots' on the cathode as related to flicker noise, seemed to make sense that varying cathode temperature might be a way of moving the locus of emission about on the cathode.
Starvation, presumably involves emission from just a small location on the cathode, which may or may not be 'noisy' in a flicker sense, whatever the mechanism of that is. Or so I think, but might well be wrong and would be very interested in your views, Merlin ?
LD
The flicker effect tends to dominate at 'normal' operating currents, i.e. above 1mA, where we run 99% of our HiFi tubes. Below 1mA shot noise may dominate, and this is reduced by lowering heater voltage. In other words, reducing heater voltage is likely to improve noise when you're using a 12AX7, but probably not with other valves, since you nearly always run them above 1mA.I thought that since you observed heater voltage to affect noise, it must do so by the flicker effect, which is dominant.
I don't want to make any bold statements about the mechanism of starvation, but since we're only talking about modest reductions in temperature, and still well within the space-charge limited region of operation, I would think 'hot spots' an unlikely explanation?Starvation, presumably involves emission from just a small location on the cathode, which may or may not be 'noisy' in a flicker sense, whatever the mechanism of that is. Or so I think, but might well be wrong and would be very interested in your views, Merlin ?
Thank you, Merlin. A few loose ends still make me curious though. Shot noise strictly shouldn't be temperature related....then there's the fudge factor attributed to 'space charge smoothing'...... and S/N ratio should improve with anode current... and kT usually means thermal noise source I think?
Somewhere in a 60's paper I recall reading that flicker noise correlates with oxide coating porosity. That doesn't sit well in the space charge 'virtual cathode model' I think? Fits better with a locus or region of emission from the cathode, especially at starved anode current or low cathode temperature perhaps?
But yes, 1mA is not very starved in the scheme of things. And shot noise is white, whereas flicker noise is pink, and they sound quite different.
LD
The space charge smooths the cathode output, but only at high frequencies. The cathode itself could have fluctuating emission at all frequencies, but we don't see this because of the space charge. Just a guess.luckthedog said:Somewhere in a 60's paper I recall reading that flicker noise correlates with oxide coating porosity. That doesn't sit well in the space charge 'virtual cathode model' I think?
Hmm, sounds like you're thinking of Schottky's theorem, which includes no temperature variable, yes? But this makes no allowance for the 'reservoir' effect of the space charge, so we need to bolt it onto Schottky's theorem. This gives us the shot noise in an ideal space-charge limited diode (amps squared per hertz):A few loose ends still make me curious though. Shot noise strictly shouldn't be temperature related....
iN^2 = Γ^2 . 2 . q . I
Where Γ is the space charge smoothing factor.
But Γ^2 itself is proportional to cathode temperature, which by substitution leads to a more familiar formula for shot noise in a vacuum diode:
iN^2 = 4k (0.633 T) / r
Where T is cathode temperature and r is the diode's internal resistance.
Thus shot noise may alternatively be interpreted as the Johnson noise of r, where the space charge has an apparent cooling effect, making r appear cooler than the cathode by a factor of 0.644. But the space-charge smoothing factor is derived for an ideal diode, whereas real valves don't always manage to muster this figure, so yet another fudge factor is invoked: σ. This number isn't a unique variable but an umbrella for all the tiny unknown factors that cause a valve to deviate from Child's law, which is mixed up in the values of both Γ and r.
Lots of theories were put forward. Who knows which one is right! Not me at any rate.Somewhere in a 60's paper I recall reading that flicker noise correlates with oxide coating porosity.
Thank you, Merlin. I do find this hard to love though.
Any reservoir of charge carriers would be depleted by lower cathode temp, and by grid-cathode field near starvation. One might then expect smoothing factor Γ (as defined) to vary inversely with temp. But, empirically, the opposite is seen: noise falls directly with cathode temperature at low anode current.
What's more, Γ should vary inversely with anode current, as it is based on statistical interaction between carriers whose number increases within the conducting 'stream'. Whereas, the opposite is seen.
I just find it a bit of a fudge. Once the fudge factor has to be dependent on cathode temperature, and some loose ends dangle, I suspect the mechanism isn't fully understood even if the resulting equations empirically mostly work for practical purposes.
PS: maybe the charge carriers themselves have a 'temperature' which varies with cathode temperature, and a resistance, overall resulting in a noise source with conventional kT term ?
LD
- Tubes / Valves
- Reduced Heater voltage to reduce noise
