redesign amp need
Could anyone get this amp to put out 250ws?
Okay, after having put my monitor on the side and rearranged my neck i wonder where you get your ground from ?
You should have a split supply (like 2x36v in series with ground in the middle) or have a virtual ground.
As you can see you have -10v for v- and +60v for v+. This will float as it is in its mood and you have no defined inputvoltage.
I am still convinced that your outputstage protection does not work.
Mike
Try those values, it may work fine
You will need to change some resistors into trimpot...the 100 ohms units, and also the input 1K or 1K5.....using fix plus series devices, to equalize exactly the current to both halves and to reduce the of set to minimum.
It is around 32 milivolts, and of course, can be reduced.
This amplifier was only simulated, it was not assembled.
Thank you to call me to help.
But may work fine.
regards,
Carlos
considering ONLY the output stage and ignoring the earlier comments on the design applicability.
You will need about 4pairs of MJ15003/4 for 250W into 8ohms with a phase angle of 60degrees and Tc max<45degreesC running on about 72Vrails drooping to about 69V fully loaded. This same output stage will also drive 4ohms to 35degrees phase. But most speakers have much larger reactance than this.
The suggested stage is for 8ohms speakers or above.
I do not know if the drivers could cope with 4pair but if you proceed I can do the calculations for you.
You will need BIG sinks to keep this much power that cool if you set up a large Iq (4pairs @ 50mA/pair) or squeeze lots of output power from the amp. If you can keep them cool the transistors are capable of driving your output all day at any audio frequency.
