i like to hear music while cooking or drinking coffee that is why i decided to build a sound system for my kitchen. i did not want to buy new technology and wanted just to recycle parts i had home. so i did this:
1. amp i have got from a friend as he did not need it anymore: s-m-s-l samp 03 ta2020 40w
2. speakers i did not use for years: radiotehnika s30b
all analogue. the size of the amp is small that is what i needed. the amp is powered with 12V. input to amp goes via 3,5 jack and i did plug in a smart phone or mp3 player to listen to music.
then for some reason the amp broke (no sound on left channel) and i wanted to replace it. i could not use the normal sized amps as they would not fit into the kitchen shelf. and did not want to buy a new amp like the CN one. after some time of thinking a noticed that the broken amp was powered by 12V so the idea came to use an old car radio which uses the same voltage.
3. the replacement amp/car radio: from a friend i have got this one: blaupunkt valencia
just had to buy the special cables that can be plugged in to the radio.
works fine. is louder and the old analogue sounds better then the todays china amp, did cost nothing. and saves nature 🙂
Yep, mounted a pre-used car radio/cassette player on a shelf in my garage back in the day.
Courtesy of a beefy 12V dc supply and some big homemade speakers it sounded great as an accompaniment to hammering, sawing, cursing etc.!
good idea Galu, i recycled the broken CN amp and put it in the cellar with one speaker. MONO. did just cross over the LR channels with a cable. still usable for LOFI conditions.
(BTW: The DX link to the amp bounces.)
Got a dandy Sony boom box from the thrift store for $5. AM/FM & dual cassette with Aux in. Feed the aux from an mp3 player.
Doc
Doc
not sure what happened to that link. it worked months ago... anyway here is photo of the cellar sound system. speakers sony. wire cut from an old bikes backlight (copper 0,5mm). player sony nwz with rockbox.org installed.
is enough for the size of the cellar.
behold the Low Fidelity mightiness: sound system for an old cellar - Album on Imgur
edit--- does the boom box have an subwoofer?
Not visible. From outside looks like two accoustic suspension speakers and two tweeters. Don't recall inside. Sounds okay.
Doc
Looks near identical to this, except has slide pots.
after .5 year i did finally took the step to install the FM antenna. the length is not optimal but it plays.
did use this kind of calculator: Wavelength Frequency Calculator
- Design & Build
- Construction Tips
- [recycling] a sound system for a kitchen
