Recommended relay for line level switch
I am currently changing my setup to active speakers, which has been complicated due to the fact I want to use my 8 channel pre-amp for stereo music and 5.1 AV.
For stereo music, the pre-amp will receive 8 channels of x-over'd DSP'd from a PC via HDMI.
These 8 channels will be passed onto my active speaker power amps via the pre-amp outputs (line-level)
For AV, the same pre-amp will receive 5/7.1 from a media player via HDMI.
In this scenario, the pre-outs need to be connected differently;
o The L/R outputs will be sent to misiDSP for x-over/DSP, then split and connected to the active speaker power amps
o The centre/surroundLR will be connected to their respective power amps
So in summary, my active speaker power amps need to receive a signal either from my pre-amp (for music) or a miniDSP (for movies) and somehow auto-switch
I'm thinking of a simple solution with 8 relays (1 for each channel) - when no power is applied to the relays, my active-amps receive the signal direct from the pre-amp, but when the relays are powered up, the connection changes to the miniDSP.
Therefore I would be grateful if someone could recommend a suitable relay for this application. I'm not sure if a relay will impact SQ, or whether the impact will vary depending on whether the relays are energized or nor
Help/advice appreciated
Latching relays would be better in this application.
If you use 5VDC for the relays I recommend the following:
I personally like 4.5V Panasonic AGN2104H.
reliable single coil DPDT type.
Mouser No: 769-AGN2104H.
Omron 6GK anyway are a very good choice. Here is a 4.5V omron equivalent.
Mouser No: 653-G6JU-2PY-DC4.5
This project on Amb.org is a DIY project that can be configured for your needs I guess.
